| Mud buddy lower seal housing http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=75243 |
| Author: | Mattjw [ Thu Aug 13, 2020 9:14 pm ] |
| Post subject: | Mud buddy lower seal housing |
Hello, does anyone know how the lower seal housing is held onto drive shaft tube? The model is a year 2000. Thanks |
| Author: | Russ [ Fri Aug 14, 2020 6:06 am ] |
| Post subject: | Re: Mud buddy lower seal housing |
The housing is part of the tube. Should just be a cap on the end with 2 flat sides that's reverse threaded (righty loosey lefty tighty) to put a big crescent wrench on and unscrew it. The seals are in the cap. #CFFITR #mudmotor>physics |
| Author: | Glade [ Fri Aug 14, 2020 11:31 am ] |
The bearing housing is pressed onto the drive tube. The seal cap is reverse threaded into the bearing housing. |
| Author: | Mattjw [ Fri Aug 14, 2020 8:13 pm ] |
I appreciate the info. Do you know how much clearance there should be between the housing cap and the nut that is closest to it? |
| Author: | bpgast [ Sun Oct 18, 2020 5:40 pm ] |
1/8 to 1/4inch. |
