It is currently Thu Mar 19, 2026 4:38 am
[ 5 posts ] |
Mud buddy lower seal housing
Mattjw
Hello, does anyone know how the lower seal housing is held onto drive shaft tube? The model is a year 2000. Thanks
| Thu Aug 13, 2020 9:14 pm |
Russ
 Re: Mud buddy lower seal housing
The housing is part of the tube. Should just be a cap on the end with 2 flat sides that's reverse threaded (righty loosey lefty tighty) to put a big crescent wrench on and unscrew it. The seals are in the cap.
#CFFITR #mudmotor>physics
| Fri Aug 14, 2020 6:06 am |
Glade
The bearing housing is pressed onto the drive tube. The seal cap is reverse threaded into the bearing housing.
| Fri Aug 14, 2020 11:31 am |
Mattjw
I appreciate the info. Do you know how much clearance there should be between the housing cap and the nut that is closest to it?
| Fri Aug 14, 2020 8:13 pm |
bpgast
1/8 to 1/4inch.
_________________ MB 35hp LT/1754 Grizzly
| Sun Oct 18, 2020 5:40 pm |
[ 5 posts ] |
