For Sale: 2007 Pro-Drive 32hp stage 1
For sale: 2007 Pro-Drive 32hp with stage 1 kit. Stage 1 mods include Iron heads, q exhaust, Mikuni 42mm carb bought in 2017. New lower unit gears and clutch in 2016. Motor runs but has issues. Hairline crack in crankcase leaks a little oil. Probably solve with some JB Weld. Rough idle and some backfire out the carb and filter. Four new push rods. Carb rebuilt. K&n air filter. New plugs. New oil. Prop measures 12-1/4”. Compression is 130 on both cylinders. Valve lash set to .005”. Manual reverse manual trim. Two sets of gaskets and carb rebuild kit included. Might keep the BPS exhaust but have stock exhaust to replace. Can send more pictures if needed. Located in San Antonio, TX. $3,000 OBO
