Pintail58
Joined: Fri Feb 06, 2009 8:17 am Posts: 578 Location: Lafayette , La on da outside
 Foreman 500 lift ???
All right I have a 09 foreman 500 and am looking at putting aftermarket wheels and tires on it maby a 2" lift. any suggestions? I will be keeping my factory wheels for a few WMAs that I bow hunt.
_________________ Shoot 1st ask later 14' leaker w/ 20hplt Shootin time Teal Season 2010 http://xrl.in/64aw #countdown
Thu Feb 10, 2011 12:52 pm |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
 Re: Foreman 500 lift ???
Call Turner Cycles in Humble Tx. and get his heavy u joint for it. Lift and more tire eats factory u joints on these bikes.
_________________ 18x54 WC custom 36PD EFI
Thu Feb 10, 2011 4:13 pm |
SmokeEater829
Joined: Sat Jun 13, 2009 8:48 pm Posts: 1830 Location: Belle Chasse, LA
How big are you looking to go with your tires? I'm running 26's on mine with no lift. And could probably go bigger.
_________________ Mud Buddy 4500 Black Death hauling the Uncle J 18x58
Thu Feb 10, 2011 4:24 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
I put an Xtreme lift on my rubicon and it was around 100 bucks and i installed it myself. Not hard to do and make the stance of the bike look good.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Thu Feb 10, 2011 5:14 pm |
Cammander26
X2 on 2inch xtreme lift, 29.5s but you have to trim the plastic where your feet go behind the pegs, vision wheels (the bead crush is twice as much then any others), but you should be ok with out triming anything if you go 28s. Had the same on mine 2inch 29.5s outlaws vivion wheels (black)
_________________ TRYIN' TO LEAVE A CARBON FOOT PRINT! BUMMIN RIDES AT THE MOMENT, UNDER CONSTRUCTION!
Thu Feb 10, 2011 6:56 pm |
Cammander26
go 10 wide all the way around
Thu Feb 10, 2011 6:57 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
If you want it to look clean put IFS wheels all the way around, deep dishes on the back (IRS wheels) look retarted to me on the back and shallow wheels on the front, the 2" lift will look good with 28's and you can run your stock U-Joints they are very strong, If anything breaks its gonna be the axles before anything. Been through plenty of axles, never a u-joint.
Thu Feb 10, 2011 8:31 pm |
muddawgchuck
Fri Feb 11, 2011 7:54 am |
Pintail58
i'm looking to go with probably some 28s. I don't dawg my bike at all, just the factory tires have left me in the field b4 by the goose blind. I'm just looking to go wherever on the property w/o having to hang on the levees. Will I have to put a lift with the 28s and also should I go ahead and change my axels / ujoints?
Fri Feb 11, 2011 8:46 am |
muddawgchuck
If thats all your gonna do with it i would just go with some more aggressive 26s and save yourself the trouble of breaking stuff like axles and u joints.
Fri Feb 11, 2011 9:03 am |
mudbutt2269
Joined: Fri Oct 08, 2010 9:21 am Posts: 204 Location: Houma LA
I have a 2007 foreman with a two inch that i put on really wasn' bad to do. Right now i have some 27 itp mudlights and they are not that good a guy i know has some 26 mud bugs same bike and he eats my lunch in the mud
MY 00.02
_________________ 18x48 homemade skiff pushed by a 2010 36 prodrive tiller drive long shaft, camo, with hydro trim and manual reverse
Fri Feb 11, 2011 2:49 pm |
take'emgator
save ur trouble and put tracks
Fri Feb 11, 2011 8:48 pm |
Cammander26
i ran 28 inch baks with a 2inch lift and and no after market axels never broke any thing
Tue Feb 15, 2011 8:22 am |
