biglinz1
 Extrema 2 misfire problem
The last two times I have been out my gun has not gone off when I pulled the trigger. There is no mark on the primer on the shell then I cycle it by hand to eject the shell and it fires it was not the first time I had shot either day. The gun works fine before and after that happens.
| Sat Dec 24, 2016 1:06 pm |
wade_660
 Re: Extrema 2 misfire problem
Check the o-ring at the top of the forearm. Pretty common issue. If you can't find it, pm me and I'll send you a pic of where it's at.
| Sat Dec 24, 2016 5:29 pm |
teammarshmafia
Joined: Tue May 14, 2013 2:18 pm Posts: 478 Location: southeast, Louisiana
When was the last time you took the bolt apart and cleaned it reason I asked is I've had some gummy trash built up on the firing pin on mine and it did the same thing
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom Jus nut up and grab a handful of throttle
| Sat Dec 24, 2016 7:15 pm |
biglinz1
I am gonna check that o ring. I cleaned it not too long ago but I put that thing thru the ringer. I am gonna pull it completely apart and clean it up real good.
| Sat Dec 24, 2016 9:10 pm |
wade_660
Look at #22.
| Sat Dec 24, 2016 10:16 pm |
DUCK HEARSE
Joined: Fri Apr 06, 2012 8:48 am Posts: 3161 Location: Alabama
Common on first shot if you don't release action fast and hard it will not set right against the shell and will misfire.
_________________ Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
| Sun Dec 25, 2016 12:44 pm |
biglinz1
Ok will check that O-ring. But now that you mention that I did change the shell in the chamber when I did do it I did it slow without racking it hard so it would not kick the shell too far that may be my issue but i will check it all out thanks for the help.
| Sun Dec 25, 2016 9:58 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
Also, general tip: don't use regular CLP/petroleum based products to clean the gas system.
_________________ 24x60 Dual Prodrives
| Thu Dec 29, 2016 3:51 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Throw that pile of shit in dumpster and go get yourself a new A5
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Sat Dec 31, 2016 4:50 pm |
teammarshmafia
^Lmao! An A5 couldnt hold up to half the shit my extrema 2 has been through
| Thu Jan 05, 2017 5:01 pm |
Andy
Joined: Tue Oct 27, 2015 9:44 pm Posts: 278 Location: Coral Springs, FL
_________________ Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF -Unbaffled VooDoo -Gator Glide G2 with base -Wet Sounds Stealth 10 Ultra V2 -Green LED Courtesy Lights -15" Combo LED Light Bar
| Thu Jan 05, 2017 7:51 pm |
