garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
 Re: 05 silverado......help!
i want my truck to pull shit once i get gears of course and pull on side of a regular truck and spank that ass
Mon Apr 04, 2011 8:33 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
4.88 gears, transgo shift kit, ls1 cam
_________________ I gave up mud motors
Mon Apr 04, 2011 8:34 pm |
JBREAUX
Joined: Tue Jan 13, 2009 8:12 pm Posts: 412 Location: soufff la
Throw some gears and a torque converter in it get a tune and that will be a night and day difference, if you want more then its headers and cam, more then that then shoot yourself in the foot for not just getting a 6.0 from the get go.
Mon Apr 04, 2011 8:37 pm |
garrettpearce
j im not drag racing pulling my skiff lol just hard to explain but def lacking power
Mon Apr 04, 2011 8:45 pm |
T-Bubba
i think being under geared is your main problem..
Mon Apr 04, 2011 8:50 pm |
whytry85
Joined: Mon Nov 01, 2010 7:18 pm Posts: 276 Location: East Texas
a tune would def help. i would go to someone with experience in LS based motors though that way you can get the best bang for your buck. not all tuning shops are the same. some use different variations of tuning software andi have found that hptuners is by far the best program to run on any LS motor. goes into alittle more detail than some others. my boss had an 03 z06 vette witha p1sc procharger that we actually built a lq9 block that was punched to a 428 stroker. ran 9.92 in the quarter and thats what we tuned his with...
but none the less, hope ive helped in some shape or form...
_________________ 1748 prodrive 36 fpr w/ some bolt ons...
Mon Apr 04, 2011 8:52 pm |
garrettpearce
def thanks to everyone for the help
Mon Apr 04, 2011 8:55 pm |
whytry85
Mon Apr 04, 2011 8:57 pm |
garrettpearce
ive heard tons about the vette servo what is it?
Mon Apr 04, 2011 8:59 pm |
JBREAUX
Gotcha, I get carried away easily. If you think its something other then gears, at a minimum get it checked for codes more then likely it will be a evap fault and won't affect anything performance wise. But it's the first step to diaging your prob if there is one. Bring it to autozone i'm pretty sure they will check it for free or you can pick up a obd2 scanner for 50$
Mon Apr 04, 2011 9:03 pm |
garrettpearce
yea lol thanks
Mon Apr 04, 2011 9:07 pm |
JBREAUX
And google the vette servo theres tons on it, It basically just firms up your 1-2 shift
Mon Apr 04, 2011 9:12 pm |
whytry85
Mon Apr 04, 2011 9:14 pm |
T-Bubba
the 1st to second shifts are better with the vette servo... its a shift servo from the 4l60e in a corvette.
Mon Apr 04, 2011 9:15 pm |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
These are the guys to get a transmission from if you need one for the 60e transmissions http://www.finishlinetrans.com/
Mon Apr 04, 2011 9:16 pm |
whytry85
Mon Apr 04, 2011 9:20 pm |
garrettpearce
thanks brad. just changed my trans and yep it was the second gear clutch that went out.
Mon Apr 04, 2011 9:22 pm |
BradS
Mon Apr 04, 2011 9:24 pm |
whytry85
Mon Apr 04, 2011 9:45 pm |
MaXXis85
Gears, Tune, and PROPER exhaust (straight pipes are the worst performace wise for a LS motor unless you stay at 5500-6000 RPMS all day). Keep the stock exhaust and just replace the muffler with a flow through muffler of you choice and that will be fine up to 500 RWHP. Your biggest hinder is the lack of mechanical advantage once you hit over drive and the HUGE gap between 1st and 2nd gear in the 4l60e tranny isnt the best either.
SOme people reccomended a cam and converter, Yes they help power, BUt it will make the powerband HIGHER. If you want to pull your boat, and still have some jump to make a bigger truck move a little quicker keep it simple. 4.56 gears, a custom tune, and a good exhaust, and you will be satisfied with your truck. Then if you want more, get a FLT trans, Yank converter, and a cam to make power. Also make your the cam/ converte compliment each other.
Tue Apr 05, 2011 6:22 am |
wade_660
try blackbearperformance.com they are great. just got my tune back and it is a night and day difference. You really need gears too though
Wed Apr 06, 2011 8:16 pm |
garrettpearce
forgot to mention after it sits for hours i get in it and right when i crank it up it seems peppy for about a min the back sluggish
Wed Apr 06, 2011 8:50 pm |
BradS
Take it to a muffler shop and have em check your cats
Wed Apr 06, 2011 8:51 pm |
MaXXis85
The peppyness and the sluggishness is from Torque management. At times you get awesome power feel and other times its a dog.... Its GM's way of making the poor shitty 4L60E trans last. Seldom will a stock cat get plugged in a gm. Ohh and dont take them off without a tune. It will run like shit Stock cats on GM's are NOT restrictive so do all the old school blah blah cut dem cats off is a NONO....
Thu Apr 07, 2011 6:29 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
I had an 04 GMC 4.8L single cab, thing was a turd getting on the highway and pulling, i put some Headman short tube headers, Super 40 flowmaster Hypertech III tuner and 410 gears in it with a shift kit, all i can say was that sucker would scream for jsut doig that to it. Your horsepower on GM motors comes around the 30mph, 2600-3000rpm mark is where i found most of my power stock, i put the 410 posi track with a locker in and i could peel your eyelids back at a dead stop all the way through the gears.
Thu Apr 07, 2011 9:49 am |
MaXXis85
Thu Apr 07, 2011 10:35 am |
