Acid Question... ( Not LSD )
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=7&t=10096
Author:  earl33 [ Mon Jun 07, 2010 10:01 am ]
Post subject:  Acid Question... ( Not LSD )
All the boat painter's say acid bath, to etch the aluminum before painting.....
Alot of talk about AlumaBright.... ( and alot of companies out there make this stuff )
I have found Phophoric, Hydrofluoric and Muriatic Acid...
What type of acid would y'all recommend? Or does it really matter?
Confused as hell
Earl33 :? :?
Author:  craig [ Mon Jun 07, 2010 10:03 am ]
Post subject:  Re: Acid Question... ( Not LSD )
Aluminum Brightener.
Author:  earl33 [ Mon Jun 07, 2010 10:08 am ]
Author:  POKER1 [ Mon Jun 07, 2010 10:11 am ]
Spot test both and see what it does.
Author:  jordy [ Mon Jun 07, 2010 10:13 am ]
im no pro at this but i used an acetone based cleaner that i got from work and it cleaned the hell out of my boat and semi-etched it. then primed and painted. this was a few months back and no problems.
Author:  blaze [ Mon Jun 07, 2010 12:06 pm ]
What ever you do wear thick gloves. The acid in alumbright will get under your nails and cause a very painfull feeling. Then they will go numb and by that time you end up in the ER and its to late. They will have to scrap out the build up under your nails. Saw two people in the ER with that and they said its like no pain they ever felt before.
Author:  Shadow [ Mon Jun 07, 2010 12:52 pm ]
I'm using the pink coil cleaner for Airconditioning fins. Supposed to do the trick... do not get on skin!!!!!! :mrgreen:
Author:  quackconsumer [ Mon Jun 07, 2010 1:11 pm ]
The will all work, but I have found da ones wit hydrofluoric acid works da best.
Author:  B.M. Barrelcooker [ Mon Jun 07, 2010 3:58 pm ]
owsley is the best......better get the blotters though because the ones on the pez are so good you can burn through a whole dispenser and if you got a clown face pez dispenser full of owsely acid you are in for one freaky ride.
Author:  earl33 [ Mon Jun 07, 2010 4:14 pm ]
Author:  earl33 [ Mon Jun 07, 2010 4:20 pm ]
Author:  B.M. Barrelcooker [ Mon Jun 07, 2010 6:56 pm ]
I got some muratic at lowes and i mix it up in a bucket and throw a handful of chlorine in it befor I mop it on .......better wear a mask though.
Author:  quackconsumer [ Tue Jun 08, 2010 6:31 am ]
Author:  UNCLE-J [ Tue Jun 08, 2010 7:00 am ]
so,
now that your question is answered...
Can we get to some talk about LSD?
Author:  earl33 [ Tue Jun 08, 2010 7:13 am ]
Author:  UNCLE-J [ Tue Jun 08, 2010 7:39 am ]
Author:  Shadow [ Tue Jun 08, 2010 1:26 pm ]
