It is currently Thu Jul 17, 2025 6:50 am
Reply to topic  [ 33 posts ]
 question for you gator tail guys
Post question for you gator tail guys
alright so I have a 18x54 extreme series gtb with a 35 gtr stock and I am wondering why I can't get speeds like i hear about is it that the extreme series is a slower hull but better for turning I am asking this because the first time i took her out I had my wife and myself in the boat tank of gas and normal stuff and hit 26.3 which is the fastest i have got her to go and since then putting a few more hours on it it seems to have slowed down about I thought with the break in it would pick up some. This tuesday I ran it by myself with about 4 gal of gas trolling motor and battery and fishing gear and could not get over 25.2 . I am not looking to be a speed deamond just wondering if this sounds correct give me your imput thanks
18x54 xtreme huntdeck 35gtr
camo designs custom paint
Thu Oct 21, 2010 8:43 pm
Post Re: question for you gator tail guys
what rpms are you turning?
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Thu Oct 21, 2010 8:47 pm
wow, is it a new motor, measure your prop, also placement of weight in the boat plays a big factor
Thu Oct 21, 2010 8:49 pm
yes it is a 2011 cdi marine edition i turn 3850 rpms
Thu Oct 21, 2010 8:56 pm
You might be hearing some vibration from the stock carb air filter set up, mine did this, put a mikuni on it last week and all the noise went away, first hand proof that's what it was. also make sure your plate where the key switch is is really tight.
Thu Oct 21, 2010 9:00 pm
add a few mph to your top speed,thats what a lot of em do,just flat out lie.it "seems' like you goin that fast any way.
i ran with a fellow a while back,his boat supposedly ran 32-33 mph.i never seen 30 with mine,the funny thing is that i steady walked away on top end and my hole shot was faster too.he had 2 people in the boat but i think i weigh more than both of them put together.
Thu Oct 21, 2010 9:02 pm
None of that even remotely came close to helping this man out...hahahahaha
Thu Oct 21, 2010 9:04 pm
does that sound right on the rpm that i am turning
Thu Oct 21, 2010 9:16 pm
Thu Oct 21, 2010 9:18 pm
wooduck,
remember you had hit some rocks or something whenver you came meet us at the camp......it took a little off of your prop didnt it? that may be the cause. may be time to hit up GT for that prop.
Fri Oct 22, 2010 6:40 am
Eat - Sleep - Hunt ! ! !
Fri Oct 22, 2010 6:58 am
Stock, my rig ran 28 empty.. bumped 30 with a wind and current..... With myself and Joe M in caddo we ran about 26.5 WFO with an icechest and gear for the ride. Modded is a diff ball game.. I can run 30 MPH all day and 28-29 with a big ass load..
3850 and 26 sounds abotu right. Just play with your trim and see whats what.. if you trim too high you lose speed if your too low you lose speed.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Oct 22, 2010 8:35 am
Never believe what people say they run.
Fri Oct 22, 2010 9:21 am
i run a 4.42 fourty!
Gave up hunting ducks and started underwater basket weaving!
Fri Oct 22, 2010 9:35 am
Fri Oct 22, 2010 3:33 pm
the prop has minor abrasions on the tips from the rocks ima try grinding the rough spots down and see if it helps and jordy i did get my prop about the trim deal i can feel the sweet spot and believe it or not it is when the trim bottoms out in the up position and the gps shows it as well
Sat Oct 23, 2010 8:34 pm
Sat Oct 23, 2010 8:47 pm
x2, and if you do take a grinder to it, you better balance it before you put it back on.
Sat Oct 23, 2010 8:58 pm
Don't grind your prop.
What hole is your pin in? You may want to try movin it up to a higher hole.
Sun Oct 24, 2010 5:07 am
Put yer face in the myrtles.
Sun Oct 24, 2010 5:50 am
Sun Oct 24, 2010 9:21 am
So you VOID your warranty at GT - if you put the prop in the chit ???
Sun Oct 24, 2010 4:12 pm
Sun Oct 24, 2010 4:13 pm
Sun Oct 24, 2010 4:21 pm
Mon Oct 25, 2010 8:19 am
Mon Oct 25, 2010 2:14 pm
Mon Oct 25, 2010 4:47 pm
you guys must have missed where i said minor abrasions i am talking about just smoothing it back up where the small gashes are ok maybe a file just to smooth it back out i am talking just a lil brush or two thats it not reshaping the prop ok or should i just go ahead and put my brand new one on and save this one as a spare just hate to mess it up too yall dont know what i had to go threw to get this prop
Mon Oct 25, 2010 6:37 pm
Mon Oct 25, 2010 7:16 pm
Go hit some sand and it will smooth out haha.
Bayou Surface Drive
337-351-0362
Mon Oct 25, 2010 8:49 pm
Try running a new prop. My original prop had slight wear but really made a difference. I'm running less rpms but faster speeds with my new prop. Just something to think about.
1754 Gatortail Extreme / 35 GTR
Tue Oct 26, 2010 7:49 am
Dude yall are acting the fool. I got 2 little chucnks missing off th leading edge of my prop. Im still running it with no problems. Just run the damned thing.
Bayou Surface Drive
337-351-0362
Tue Oct 26, 2010 7:54 am
it wont stop me from running it i was just curious i will run it however just get there a lil slower
Wed Oct 27, 2010 7:44 pm
Users browsing this forum: No registered users and 88 guests
