It is currently Wed Jul 23, 2025 12:19 pm
Reply to topic  [ 10 posts ]
 Uncle J
Post Uncle J
Do you build any hulls using .100? I have only hit 1 fence post in 18 years, just don't have to run through stump infested terrain down here. We do run aground alot, so I was just think about .100 to reduce weight.
Mon Feb 14, 2011 8:38 pm
Post Re: Uncle J
Don't do it. The weight difference will not be noticed.
1754 Xtreme 35 GTR Stage 1
Mon Feb 14, 2011 8:42 pm
Post Re: Uncle J
i have a .100 boat. if you would see the amount of bracing throught out this boat to make it as strong as it is (not very) you would change your mind. you can grab the bow from the side and feel the boat twist.
Mon Feb 14, 2011 8:44 pm
Post Re: Uncle J
i disagree i had a boat built out of .100 and it was super light, depending on if you want crimps in the bottom it will be somewhat strong.
Mon Feb 14, 2011 8:45 pm
Post Re: Uncle J
Sounds like I need to stay w/.125. What about the floor, driver box, etc. can that be made out of lighter alum to shave a few pounds off? Sounds like it will be winch mounts front and rear and always inviting friends stronger than me.
Mon Feb 14, 2011 8:49 pm
Post Re: Uncle J
I would want flat bottom or stepped bottom.
Mon Feb 14, 2011 8:50 pm
Post Re: Uncle J
Mon Feb 14, 2011 9:15 pm
Post Re: Uncle J
Mon Feb 14, 2011 9:26 pm
Post Re: Uncle J
Read that for greater detail.
Mon Feb 14, 2011 9:39 pm
Post Re: Uncle J
My 19x40 skiff is .100ga. I added ribs in between every rib in the bottom of the boat to stiffen up the bottom. Every year I have to beat dents out of the bottom and weld up cracks. Thats just from everyday use. It has crimps on each side and 3 corrigations on the bottom. That is a must on a .100 ga boat. I dont find the crimps hurt me in the mud. I would not reccomend that for anyone. Like above post said, the weight difference isnt gonna be alot, but the structural integrity will be alot better with 1/8.
Tue Feb 15, 2011 6:39 am
Users browsing this forum: Google [Bot] and 178 guests
