It is currently Thu Jul 24, 2025 7:47 pm
[ 6 posts ] |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 GTR Trim Problem
All my motor will do is trim up. If I push down on the switch, it trims up. If I push up, it trims up. Whats da problem? Also, my trim ram has about one inch of play in it. Meaning, if I push down on the prop end of the shaft you can see the ram move in and out of the pump about an inch. Anybody had that problem before?
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Sat Mar 05, 2011 9:42 am |
TXSHOCKWAVE
Joined: Tue Jan 13, 2009 5:51 pm Posts: 295 Location: Karankawa Lake TX
 Re: GTR Trim Problem
Someting is wrong with your relays. If the ram is moving like you say the seals are blown. It need to be resealed.
Sat Mar 05, 2011 10:35 am |
Tenpoint
The ram was replaced a couple months ago. There is no oil leaking anywhere. It kinda has me puzzled about the ram movement. I just got this thing back from GT yesterday. Looks like Im gonna have to go back again Monday.
Sat Mar 05, 2011 10:40 am |
POKER1
Is it holding the motor up or does it fall back down? If it holding then its probably not the ram. There are internal seals in them so you wouldnt neccesarily see any fluid.
Sat Mar 05, 2011 11:02 am |
Tenpoint
Yes it does hold the motor up. somethings deffinately wrong. hopefully they will replace the trim unit instead of rebuilding it again.
Sat Mar 05, 2011 12:50 pm |
WestEndAngler
MMT Moderator
Gator-Tail will make it right.
Sat Mar 05, 2011 12:56 pm |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 179 guests |
