BROOKS
Joined: Tue Jan 13, 2009 9:46 pm Posts: 4596 Location: East TEXAN Proud
 Preasure Warshers ......
You know ~ Fo several years now I've always told fellers ...... Here's the items you must have befo holy matramonys ... that you own out-rite with clear titles ... 1. A good shootin' rifle ... 2. A good shootin' shotgun ... 3. A good runnin' chainsaw ... 4. A good alumiaum boat and motor ... All these items sometimes are hard to put the afford on afters you say "I Do" ... I'ma thankin' 'bout addin' to this list ... 5. A good preasure warsher ... I borrowed one from mines naybor the other day ... Ya'lls ain't gonna believe how clean mines camp is now ..... Mines boat looks to be freshly purchaced !!!!
_________________ Git a Gator-Tail or ride in mines wake ...... MtrFact !!!!! '05 Model .... Still Number One on the Water !!!!
Thu May 26, 2011 2:49 pm |
redleg3316
Joined: Sat Nov 14, 2009 5:06 pm Posts: 414 Location: MS / were ever da rig floats
 Re: Preasure Warshers ......
Def have to have a pressure washer. No less than 2500 psi.
_________________ 1648 war eagle with a 50 Tohatsu
Thu May 26, 2011 3:13 pm |
robin2
Joined: Mon Apr 13, 2009 6:38 pm Posts: 400 Location: Pecanierre,La
Have to agree, got the gas one for the big jobs such as the camp wash'n, but dont laugh, got one of them little electric one's too. That little one is the ticket for four wheelers and such, does a whole lot better than just the hose pipe but dont take all the stickers off.
Thu May 26, 2011 4:06 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
6. Spellcheck on yore type talkin' machine.
Just messin' with ya ol' boy. I am in need of a pressure washer myself, I used to have one, very invaluble tool.
_________________ Put yer face in the myrtles.
Thu May 26, 2011 4:49 pm |
kibb
Go with nothing smaller than a 6.5 hp with a CAT or General pump. You should be at about 2800 psi with that. Anything smaller you will kick your own ass especially, when washin the driveway. I got the CAT and I don't know first hand but word is you don't need any feed pressure for it to work.
Thu May 26, 2011 5:34 pm |
BROOKS
Fri May 27, 2011 8:02 am |
BROOKS
[quote="DeathMetalDukk"]6. Spellcheck on yore type talkin' machine. You thanks thats bad ..... You 'ought to try livin' in this haid ......
Fri May 27, 2011 8:03 am |
Mudhole
Joined: Wed Jan 14, 2009 7:05 am Posts: 716 Location: NW La.
Dang it, I aint gots one, now yall brought it up!
_________________ "Gofer Everette?"
Fri May 27, 2011 8:22 am |
kibb
Fri May 27, 2011 11:54 am |
BROOKS
Good info Kibbs. Thanks ..... I'ma gonna git one soon. I litterality had no idea what I been missin' out on !!
Fri May 27, 2011 11:56 am |
kibb
I'm sure there are pumps up there with the two I mentioned but make sure they are triplex pumps not axial cam. The life expectancy of a triplex pump is far greater than an axial cam pump. I know the triplex can be rebuilt fairly easily, while the axial would probably just be shit-canned since they are probably not worth the money to fix.
Fri May 27, 2011 12:15 pm |
BROOKS
Fri May 27, 2011 12:28 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
add a bge to dat list...
mr brooks... yours list is mightys fine to da tings a man needs in hims life
_________________ I gave up mud motors
Fri May 27, 2011 12:48 pm |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
we have a Karcher 220 unit at work that has chemical resivoir and a deisel powered heater. It's a bad mofo. The chemical and heat will take the white off rice.
_________________ Sometimes it's best to just keep your fingers quiet...
Fri May 27, 2011 1:06 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
I would like to add a good hunting dog. Cause no matter what ya do your dog is never mad at u.... Wanna see who your true best friend is, lock your wife and dog in the trunk of the car drive around for a hour and see who is happier when ya let em out..
Fri May 27, 2011 1:57 pm |
redleg3316
Sat May 28, 2011 12:05 am |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 617 Location: Idaho
Ditto the triplex vs. axial pump argument. The pressure washer business is an assembly business. There are not too many makers of the pumps themselves and of the accessories (guns, tips) that go on washers. It doesn't really matter the brand of washer that you buy. The secret is making sure that whatever you buy has been put together with the best components. Usually that means Honda engine and General or Cat pump, plus a good quality unloader valve on a cart that will not rust into oblivion or fall apart.
Now here is the secret of cleaning energy, or impact force: Pressure, measured in PSI, factors into the equation, but so does the flow of water through the pump, measured in GPM, or gallons per minute. In fact, GPM is exactly twice as important as PSI in contributing to cleaning energy.
If you wanted to double the measurable impact force of any given pressure washer and you went to do it by increasing the GPM, you would get it done by doubling the GPM. If you wanted to do it by increasing PSI and you left the GPM the same, you would have to QUADRUPLE the PSI.
Give me a 2000 PSI washer with a 4 GPM flowrate any day over a 3500 PSI, 2 GPM washer! Selecting your washer specs should be relative to the kind off things you want to do. For washing down equipment, you don't need that much cleaning energy. For blasting flaking paint from a rafter overhang two storys up on a building, you need power.
Hope this helps.
Sat May 28, 2011 10:04 am |
idabilly
Pressure washing is most effective if you bring three factors into play: Cleaning energy (discussed in last post) Cleaning chemicals, i.e., soap Hot water
Hot water pressure washers are out of most people's budget, but everyone who buys a washer should get one with a good chemical injector. You put a chemical injector tip on your washer, turning it into a glorified Hudson Sprayer, apply chemical, wait, put your high pressure tip back on and rinse. Works much better than not using soap.
Don't buy a washer without a chemical injector.
Sat May 28, 2011 10:09 am |
kibb
X2 on the GPM/psi stuff. Just didnt wanna type all that on the phone.
Sat May 28, 2011 11:37 am |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
I got a 2700 psi 2.5 gpm with a 4.5 hp honda
Im not sure of the pump but I can tell ya
I love it -- I think any higher it would knock the paint off stuff (if ya hit a chip this will knock it off)
Its a black max brand
Sat May 28, 2011 11:51 am |
