It is currently Mon Feb 16, 2026 7:20 am
[ 5 posts ] |
toledo
 Best HARD bottom coat?
I was hoping yall could help me pick a bottom paint for a 12ft flat bottom that will have a small surface drive on it. It will likely be hitting some rocks and gravel and will be drug across rocks and gravel on dry ground. I hear good stuff about the gator glide but Im not sure the G4 will hold up to that kind of use. Is there a better option out there?
| Thu Jul 26, 2012 9:27 am |
cb5331
 Re: Best HARD bottom coat?
uhmw
| Thu Jul 26, 2012 11:02 am |
toledo
What would the weight be to cover the bottom of a 1232? I really dont need to be adding much weight to the hull. It doesnt matter a whole lot if I tear the boat up but I would prefer not to. Adding 25+lbs isnt an option though for a boat that will be launched by hand with one person.
| Thu Jul 26, 2012 11:40 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
Can't weigh more than the can of stuff weighs... pretty small hull too...
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Thu Jul 26, 2012 3:19 pm |
Bust Em
I used "Coat It" on my boat. Much cheaper than Steel Flex and just as good, but you have to use twice the recommended coverage.
| Wed Aug 01, 2012 1:07 pm |
[ 5 posts ] |
