13 pistols
Joined: Wed Jul 29, 2015 12:56 pm Posts: 13 Location: ALABAMA
 Prop replacement problem
Knocked the f*** out of my prop an now need to replace it. Didn't bend the shaft, just one blade it is a screw on prop and the shaft has a little rust on the threads. WD40 hasn't broke it free yet. Don't want to hit it too hard and chance bending the shaft. Any help?
| Mon Feb 01, 2016 9:13 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: Prop replacement problem
What kind of mud motor we talking about here . Sd. , longtail. , make ?? A little more info .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Mon Feb 01, 2016 9:27 pm |
13 pistols
04 25hp Mud Buddy HD. Bought it used 3 years ago.
| Mon Feb 01, 2016 9:56 pm |
Bigbend
Try PB blaster, WD40 won't break free that kind of stuff. Do a search, there are some other products people have used, I always use PB blaster because you can find it at autozone, Walmart etc.
Spray it down liberally, repeat for a couple days to let the science happen, then give it hell.
| Tue Feb 02, 2016 5:00 am |
SETx Longtail
Have you tried searching "stuck prop" yet? There are probably two dozen threads that will pop up... Take a look.
_________________ #CFFITR
| Tue Feb 02, 2016 5:25 am |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
You're gonna need a sledge hammer, plasma cutter, and vice grips.
| Tue Feb 02, 2016 6:25 am |
Gigafowl
A little heat helps - so does a prop removal tool....
| Tue Feb 02, 2016 8:07 am |
JIMMY W
Not worth fucking with!!About like a godevil,Throw that pile of shit in dumpster and go see Kyle at GatorTail!!thank me later
| Tue Feb 02, 2016 11:17 am |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
| Tue Feb 02, 2016 11:21 am |
Russ
And the gt fanboy runs off another customer....
| Tue Feb 02, 2016 11:41 am |
JD145
Joined: Wed Jun 04, 2014 9:01 pm Posts: 1289 Location: SWGA
_________________ 1854 Prodigy DPE Level 3 HDR
| Tue Feb 02, 2016 12:38 pm |
DENNYEDWARDS
Make yourself a prop removal tool, using a 2" wide piece of 1/4" thick flat stock about 4' long. Drill a 7/8" hole in it about 3" back from one end. So it fits over threaded part of shaft. Put a small pipe wrench on the bushing behind the prop with a cheater pipe on it, that will touch the ground and power it off using leverage, most come off pretty easily after soaking with panther piss Liquid wrench.
| Tue Feb 02, 2016 12:51 pm |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
Once you get it off see if you can get a hex shaft for it instead of the threaded one. That's the best thing anyone could have ever done for one of these motors...going from a go devil with threads to the gatortail with the hex shaft was the shiz nit
| Tue Feb 02, 2016 1:46 pm |
BlueShamu
PB Blaster....plenty of it and overnight soak.
| Tue Feb 02, 2016 1:47 pm |
