Capt. JJ
 New Crawfish Boiler
FInally built my a new boil rig. I had pictures on here before of the one I had built with the burner tubes inside the pot like the cajun fryers. Well that one was just kind of an experiment to see if it would work, and since it did, I finally got around to building a new one, and trying to improve upon the design.
I added some 1/2" round rods into the burner tube, to sort of act as a reverse heat exchanger. I also turned the tube down out the bottom of the pot, then double bottomed the pot to try and make use of the exhaust heat.
I ran out of daylight yesterday evening to do much testing, but it got 30 gallons of water boiling in about 18 minutes, but that is with just a 10 psi fryer regulator and a single flame. Whats awesome about it is ther is no stray heat, just gentle hot air coming out the louvered discharge. I still need to place with the orrifice some, think i need to pull more air in , but all and all I'm pretty pleased with the outcome.
| Mon Mar 07, 2016 10:47 am |
Capt. JJ
 Re: New Crawfish Boiler
Few more pictures of it finshed
| Mon Mar 07, 2016 10:51 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
That's dam nice!
Top notch work!
Sent from my beeper
| Mon Mar 07, 2016 12:41 pm |
Southland_Hunter
Joined: Fri Jul 24, 2015 1:25 am Posts: 51 Location: Se Louisiana
Let me know when you test it out! Looks good.
_________________ 16 x 48 SWC with 37GTR
| Tue Mar 08, 2016 7:55 am |
swamp_fox
Joined: Tue Oct 08, 2013 5:39 pm Posts: 265 Location: St.Amant, LA
Nice!
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ 17'Extreme Metal Fab. Skiff - 23 GDLT
| Tue Mar 08, 2016 6:40 pm |
Randy S
Joined: Sun Oct 02, 2011 4:03 pm Posts: 313 Location: NELA
Nice design and well executed!
| Tue Mar 08, 2016 6:52 pm |
Rooterpig
Joined: Sat May 19, 2012 6:48 am Posts: 125 Location: East central Florida.
Looks cool as hell. Good job.
| Tue Mar 08, 2016 7:23 pm |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
I've been seeing more and more boilers like that in the past two years. My girlfriends dad has a miniature one and its damn nice to cook with. Quick easy and simple.
| Wed Mar 09, 2016 9:56 pm |
DeoVindice
Joined: Thu May 02, 2013 10:45 am Posts: 228 Location: South Alabama
Very Nice!
| Thu Mar 10, 2016 1:29 pm |
Waterfowl Fool
Joined: Sat Jan 14, 2012 8:58 pm Posts: 354 Location: Okeechobee - Florida
damn son you people are serious about them mud bugs !
_________________ Proud to have served; USMC 90-94 I earned it VFW - Life Member
REPORT STOLEN VALOR !!
| Sun Mar 27, 2016 4:24 pm |
GDSArgo
Joined: Tue Dec 03, 2013 12:39 pm Posts: 341 Location: Houston Delaware
What you doing with the proto if it's still in good shape I'm interested in it.
_________________ Dont criticize a farmer with your mouth full
| Sun Mar 27, 2016 5:43 pm |
banded-mallard
Resurrect an old thread.
How is that internal burner working out? Still going well? Any different modifications?
| Tue Apr 25, 2017 5:59 am |
Capt. JJ
Working well. It's amazingly efficient. Can boil 9 sacks of crawfish on a regular little 5 gallon propane tank.
Seems to be holding up well. I think there is still room for improvement on the actually burner design. I'd like to build another one just to try something new and different, but I just aint had the time.
Between travel obligations with work, building a new house and had another baby, I hadn't built a boat or done any welding work in probably over a year.
Sorry to any one who is hit me up on here for anything! I'm finanlly getting caught up and hope to get back to welding. Any one needed anything from me, hit me up again
| Tue Apr 25, 2017 9:04 am |
banded-mallard
| Tue Apr 25, 2017 11:05 am |
Capt. JJ
I'm about in the same boat. Forming up a 40 x 60 slab in the next couple weekends. Going to build the shop myself, so you will probably get a jump on me, but I hope to be up and going by early/mid summer.
I have about an 3/4" to 1" (id have to measure to be sure) of clearance between the burner tube and the bottom of the pot. No problems at all with stuff getting caught under it, and it even allows you enough room to get a soap and sponge in there. The first one I built like this, I had hardly any clearance under it, and did have a little bit of an issue, although not that bad with claws getting caught under it.
I use that large opening flat expanded metal for the basket, and that's about the only thing you have to contend with getting out of the basket is a few small claws.
I've used 3" square tubing on all the boilers and fryers I've built. Square corner 1/8" wall. I think that 3" or 4" pipe would make for a nicer look and easer cleaning, but you loose a lot of surface area going with pipe over the square tube, and in turn I don't think it would work nearly as well.
| Wed Apr 26, 2017 5:16 am |
