It is currently Mon Apr 06, 2026 1:32 am
Reply to topic  [ 11 posts ]
 Extrema 2 misfire problem
Post Extrema 2 misfire problem
The last two times I have been out my gun has not gone off when I pulled the trigger. There is no mark on the primer on the shell then I cycle it by hand to eject the shell and it fires it was not the first time I had shot either day. The gun works fine before and after that happens.
Sat Dec 24, 2016 1:06 pm
Post Re: Extrema 2 misfire problem
Check the o-ring at the top of the forearm. Pretty common issue. If you can't find it, pm me and I'll send you a pic of where it's at.
Sat Dec 24, 2016 5:29 pm
When was the last time you took the bolt apart and cleaned it reason I asked is I've had some gummy trash built up on the firing pin on mine and it did the same thing
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Sat Dec 24, 2016 7:15 pm
I am gonna check that o ring. I cleaned it not too long ago but I put that thing thru the ringer. I am gonna pull it completely apart and clean it up real good.
Sat Dec 24, 2016 9:10 pm
Look at #22.
Sat Dec 24, 2016 10:16 pm
Common on first shot if you don't release action fast and hard it will not set right against the shell and will misfire.
- Mark Twain
Sun Dec 25, 2016 12:44 pm
Ok will check that O-ring. But now that you mention that I did change the shell in the chamber when I did do it I did it slow without racking it hard so it would not kick the shell too far that may be my issue but i will check it all out thanks for the help.
Sun Dec 25, 2016 9:58 pm
Also, general tip: don't use regular CLP/petroleum based products to clean the gas system.
24x60 Dual Prodrives
Thu Dec 29, 2016 3:51 pm
Throw that pile of shit in dumpster and go get yourself a new A5
Sat Dec 31, 2016 4:50 pm
^Lmao! An A5 couldnt hold up to half the shit my extrema 2 has been through
Thu Jan 05, 2017 5:01 pm
Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF
-Unbaffled VooDoo
-Gator Glide G2 with base
-Wet Sounds Stealth 10 Ultra V2
-Green LED Courtesy Lights
-15" Combo LED Light Bar
Thu Jan 05, 2017 7:51 pm
