Extrema 2 misfire problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=7&t=69319 |
Author: | biglinz1 [ Sat Dec 24, 2016 1:06 pm ] |
Post subject: | Extrema 2 misfire problem |
The last two times I have been out my gun has not gone off when I pulled the trigger. There is no mark on the primer on the shell then I cycle it by hand to eject the shell and it fires it was not the first time I had shot either day. The gun works fine before and after that happens. |
Author: | wade_660 [ Sat Dec 24, 2016 5:29 pm ] |
Post subject: | Re: Extrema 2 misfire problem |
Check the o-ring at the top of the forearm. Pretty common issue. If you can't find it, pm me and I'll send you a pic of where it's at. Sent from my iPhone using Tapatalk |
Author: | teammarshmafia [ Sat Dec 24, 2016 7:15 pm ] |
When was the last time you took the bolt apart and cleaned it reason I asked is I've had some gummy trash built up on the firing pin on mine and it did the same thing Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | biglinz1 [ Sat Dec 24, 2016 9:10 pm ] |
I am gonna check that o ring. I cleaned it not too long ago but I put that thing thru the ringer. I am gonna pull it completely apart and clean it up real good. |
Author: | wade_660 [ Sat Dec 24, 2016 10:16 pm ] |
Look at #22. Sent from my iPhone using Tapatalk |
Author: | DUCK HEARSE [ Sun Dec 25, 2016 12:44 pm ] |
Common on first shot if you don't release action fast and hard it will not set right against the shell and will misfire. |
Author: | biglinz1 [ Sun Dec 25, 2016 9:58 pm ] |
Ok will check that O-ring. But now that you mention that I did change the shell in the chamber when I did do it I did it slow without racking it hard so it would not kick the shell too far that may be my issue but i will check it all out thanks for the help. |
Author: | Crews [ Thu Dec 29, 2016 3:51 pm ] |
Also, general tip: don't use regular CLP/petroleum based products to clean the gas system. Sent from my iPhone using Tapatalk |
Author: | JIMMY W [ Sat Dec 31, 2016 4:50 pm ] |
Throw that pile of shit in dumpster and go get yourself a new A5 |
Author: | teammarshmafia [ Thu Jan 05, 2017 5:01 pm ] |
^Lmao! An A5 couldnt hold up to half the shit my extrema 2 has been through Sent from my SAMSUNG-SM-G890A using Tapatalk |
Author: | Andy [ Thu Jan 05, 2017 7:51 pm ] |
