It is currently Mon Apr 06, 2026 10:11 pm
Reply to topic  [ 4 posts ]
 removing planetary gear/ shaft extension
Post removing planetary gear/ shaft extension
Does the shaft extension come off once the outer planetary gear is removed? can figure out what is holding it on.
Secondly, I am Having a lot of trouble getting the allen bolts free from inside the outer planetary gear. Any advice? I was considering getting a decent impact wrench but wanted to see if there were any other options.
Thu Jan 26, 2017 7:43 pm
Post Re: removing planetary gear/ shaft extension
It just has a key, and it's a nice snug fit. I used a rubber mallet, tap all the way around on the end, it'll eventually work it's way off. Notice I used the word tap. Think finishing nail through drywall into a stud, not using a sledge through drywall in preparation to remodel. It doesn't take alot, just a few loops around it until it either falls off or you can pull it the rest of the way by hand. Make sure and use antiseize for reassembly.
Thu Jan 26, 2017 9:28 pm
Fri Jan 27, 2017 2:43 am
Yep.
Fri Jan 27, 2017 4:53 am
