| Need some suggestions http://mudmotortalk.com/mmt_v2/viewtopic.php?f=7&t=70232 |
| Author: | Bigred333 [ Sat Apr 08, 2017 5:09 pm ] |
| Post subject: | Need some suggestions |
Im a new surface drive owner. I have a 16 44 alumacraft with a 37efi GTR. My problem is the amount of tourque the motor has at full throttle. It takes almost everything I have to keep it from going to the right. Any help would be appreciated. Thanks |
| Author: | MNGunner [ Mon Apr 10, 2017 6:21 pm ] |
| Post subject: | Re: Need some suggestions |
#1 play with the trim and hole settings. If you are trimmed out of water too much, the torque goes thru the roof. On my boat there's a sweet spot. #2 You can bend the back of the skeg (on my 2014, there's a distinct tab) more #3 you can mount the motor slightly off-center (like 1" or less) to the starboard (if that's the way it's pulling) |
| Author: | Quack N Stack [ Fri Apr 14, 2017 2:26 pm ] |
Dont bend the skeg if its a cast lower unit...it wont bend, it'll just break. Move weight around or move off center |
| Author: | BERNIE255 [ Fri Apr 14, 2017 3:36 pm ] |
Or jb weld a wedge to the skeg. Or bolt a tab to the skeg to bend Sent from my iPhone using Tapatalk |
