It is currently Sat Apr 11, 2026 12:24 pm
Reply to topic  [ 9 posts ]
 Greasing Wheel Bearings(Bearing Buddy)
Post Greasing Wheel Bearings(Bearing Buddy)
I just had new Bearings installed with new Bearing Buddies last year. How much grease should I be putting in there for maintenance. Thought I have heard you can over grease them and blow out the springs.
Thanks
Fri May 26, 2017 7:32 am
Post Re: Greasing Wheel Bearings(Bearing Buddy)
First, the bearing buddies don't replace needing to repack bearings.
Having said that, I add grease until the cap just starts to compress the spring.
_______________________________________________________________________________
1542 F&F 23HP Backwater SWOMP (under construction)
"Well we don't rent pigs and I figure it's better to say it right out front because a man that does like to rent pigs is... he's hard to stop" -Augustus McRae
Fri May 26, 2017 8:56 am
Thanks Smoke. How can you tell if the spring is starting to compress? Is it a visual check?
Thanks,
Fri May 26, 2017 9:13 am
The spring is on the outside and pushes on the faceplate into the bearing. When grease starts to put back-pressure on the face plate, it will start to budge a little and compress the spring. Over the next few minutes and seconds, that spring will push the faceplate back down to its seat and push out any extra grease into the front cavity in the bearing buddy.
The trouble you've heard about is probably due to continuing to put in grease faster than it can escape around the faceplate, thereby putting too much pressure on the rear seal.
It's always a good idea to go back 5-10 minutes after greasing and wipe out any excess grease with a rag. If you drive it down the highway without doing this, you'll end up with an evenly dispersed coat of grease on the wheel. No big deal, but you can avoid it by wiping it down prior to driving.
Fri May 26, 2017 9:54 am
Thanks Smoke very helpful!!!!
Fri May 26, 2017 10:29 am
They make some black plastic covers for Bearing Buddies that will help keep your wheels clean.
GoDevil 18X44
GoDevil 35 SD
Fri Jun 09, 2017 8:58 am
Sat Jun 10, 2017 3:08 pm
And.....after you get the grease gun on the zerk, quit pushing against it. Pump the gun handle and just support the gun barrel with your other hand. If you pump grease in there and lean hard into the grease gun at the same time, you stand a good chance of blowing the seal. Let the pressure overcome the spring and push the face plate toward you. Always look at the seal after you grease them.
GoDevil 18X44
GoDevil 35 SD
Sun Jun 11, 2017 3:51 pm
Be careful removing the grease gun from the zerk as well. Mine got a little hung up one day and I just yanked it off without giving it much thought. About 50 miles later I heard a "tiiiiiiiiing." Pulling on the grease gun had loosened the bearing buddy and I lost it going down the road. Luckily it happened right in front of a Walmart (rare for me to have something work out like that).
Sun Jun 11, 2017 3:59 pm
