It is currently Sun Sep 07, 2025 6:34 pm
Reply to topic  [ 10 posts ]
 Will a weldbilt 1852 handle a 40efi mud buddy???????????????
Post Will a weldbilt 1852 handle a 40efi mud buddy???????????????
Wanting to know if it will be too heavy for the boat
Sat Oct 06, 2018 1:11 pm
Post Re: Will a weldbilt 1852 handle a 40efi mud buddy???????????
Itll be fine
#TheGhostBoat
Sat Oct 06, 2018 6:20 pm
^^^ x’s 2
That’s alotta question marks...
What’s the difference between 1 and 15 of them?
Refurbishing a Prodrive
Sat Oct 06, 2018 6:31 pm
I didn’t have enough characters to post and couldn’t figure out how to make a post, new to this deal.. Russ have you been around a similar set up?
Sat Oct 06, 2018 8:15 pm
I have seen them mounted on a 1546, 1744, 1748, 1652, etc, and on and on. An 1852 is a good size boat to run a 35hp surface drive on, and itll be fine with either a mud buddy, prodrive, godevil, or gatortail. It's not too much weight, and pretty sure the weldbilt transom has enough bracing and is built well enough to handle surface drives. Not certain, but that is an easy fix if you think it's a little anemic.
#TheGhostBoat
Sat Oct 06, 2018 8:36 pm
Thanks for the feed back I ordered the boat with extra transom bracing and they talked like they would beef it up a little more than that. I just didn’t know if a 300 pound motor would make the boat ass end heavy or not
Sat Oct 06, 2018 8:57 pm
1852 will be safe with that size motor. I run a 36 Prodrive on the back of an 1852 boat. Have owned a 35 Mudbuddy on the back of a skinny 1844 Gatortrax. My friend is a Mudbuddy dealer and I have seen many boat / motor combos of the type you describe.
Fri Oct 12, 2018 7:52 am
You should be fine both are a pile of shit!!
Wed Jan 23, 2019 7:06 pm
^ I bet my POS 40 outruns your rig :D
To the OP, My dad designed a cool little transom brace that is removable and costs about 50 bucks to make. I have it on both of my rigs and it works like a charm. Pm me and I can send you the design if you want a little more bracing
Wed Jan 23, 2019 7:57 pm
Will it work and not be too heavy on the ass end, yes. Will the engine eventually need to be removed so that you can rebuild the transom and install the proper support that surface drives require, yes.
These factory style boats are designed to have outboards on them. An outboard has a lower center of gravity than what surface drives have.
Pay attention to the bolts that secure the engine to the transom. Eventually you will probably notice that they are having to be tightened every now and then. Once it gets to that point it'll be a good idea to have your transom beefed up.
To fish or not to fish? What a stupid question.
17/54 Extreme Hull with a 35GTR with just a basic build.
Thu Jan 24, 2019 2:16 pm
