It is currently Thu Jun 26, 2025 7:31 pm
Reply to topic  [ 1 post ]
 Small Generator Specs.
Post Small Generator Specs.
For those of you looking into buying a small suitcase style generator for bowfishing/ etc..
Yamaha EF2000iS (*Est. $1,000)
Maximum AC Output 2000 watts
Rated AC Output 1600 watts
Rated / Maximum AC Current 13.3 / 16.7 amps @ 120V
Engine 79cc OHV, Forced Air-Cooled, 4 Stroke, Single Cylinder
Overall Length 19.3 in
Overall Width 11.0 in
Overall Height 17.9 in
Dry Weight 44.1 lbs.
Fuel Tank Capacity 1.1 gallons
Continuous Operation at 1/4 Rated Load 10.5 hrs.
Noise Level 51.5 - 61 dB (A)
Warranty 3 Years Limited Warranty
Honda EU2000iA (*Est. $1,000)
Rated AC Output
Rated / Maximum AC Current 16.7 amps @ 120V 12v - 8.0A DC output
Engine 4 Stroke
Overall Length
Overall Width
Overall Height
Dry Weight 47 lbs.
Continuous Operation up to 9.6 hrs. on 1.1 gal
Noise Level 53 to 59 dB (A)
Warranty 3 year residential and Commercial
Honeywell 2000i (*Est. $500)
Rated AC Output
Engine 125cc, air cooled, OHV ,4 stroke
Overall Length
Overall Width
Overall Height
Dry Weight 58lbs.
Fuel Tank Capacity 1.5 gallons
Continuous Operation 5 hrs. at 50% load
Noise Level 62 dB at 7-meters (no load)
Warranty
NOT good reviews
ETQ IN1800i (*Est. $500)
Maximum AC Output 1800 watts
Engine 3.4 HP OHV, Air-Cooled, 4 Stroke, Digital
Overall Length
Overall Width
Overall Height
Dry Weight
Fuel Tank Capacity 6.42 gallons
Continuous Operation 11 hrs. on 50% load
Noise Level Less than 60dB
Warranty
Generac ix2000 (*Est. $550)
Maximum AC Output 2200 watts
Rated AC Output 2000 watts
Rated / Maximum AC Current 60Hz 16.3/18.3 amps @ 120V/ 12v DC
Engine 126cc OHV, Variable speed,4 stroke
Overall Length 22 in
Overall Width 12 in
Overall Height 18 in
Dry Weight 49.6 lbs.
Fuel Tank Capacity 1 gallon
Continuous Operation 4.7hrs. on 50% load
Noise Level
Warranty 2 year Residential 6months commercial
Champion 2000W Inverter (*Est. $600)
Rated / Maximum AC Current 14 amps @ 120V/ 12v DC
Engine OHV, Variable speed,
Overall Length 16.3 in
Overall Width 13.2 in
Overall Height 19.3 in
Dry Weight 48 lbs.
Continuous Operation 9.5 hrs. at 25% load
Noise Level 54 dB at ΒΌ load
Kipor IG2000 Inverter (*Est. $700)
Rated AC Output
Rated / Maximum AC Current 13.3 amps @ 120V/ 12v DC
Engine OHV, single phase, single cylinder, 4 stroke, air cooled, digital
Overall Length
Overall Width
Overall Height
Dry Weight 48.5 lbs.
Continuous Operation 3.5 on full load
Noise Level 54-59 dB
Warranty
Hyundai HY2000si (*Est. $500)
Rated / Maximum AC Current 16.6/20 max amps @ 120V/ 12v 8.3A DC
Engine 125cc, 4 stroke
Overall Length 525 mm
Overall Width 330 mm
Overall Height 575 mm
Dry Weight 32kg
Fuel Tank Capacity 7 liters
Continuous Operation 5.5 hrs.
Noise Level 65 dB
Warranty 2 years
Briggs &Stratton 30473 2000w Inverter (*Est. $500)
Rated / Maximum AC Current 20 max amps @ 120V/ 12v 5A DC
Engine 105cc
Overall Length 19.5 in
Overall Width 11 in
Overall Height 17 in
Dry Weight 50 lbs.
Continuous Operation 6.5 hrs. at 25% load
Noise Level
Warranty 2 year limited
Sun Apr 10, 2011 12:30 pm
Users browsing this forum: No registered users and 53 guests
