david95
Joined: Thu Jan 12, 2012 5:15 pm Posts: 641 Location: Summerville, South Carolina
 Got em in!
Put in a order last Friday for 4 150s from econolite and got them in today. Gonna start the deck tomorrow already got the material for it. Can't wait to test em out.
Sent from my DROID RAZR using Tapatalk 2
_________________ 27 GDLT pushing a War Eagle 1542
Thu Jul 25, 2013 1:51 pm |
slingshot
 Re: Got em in!
Post some pic up when ya done wit it.
_________________ 1542 stuck to a 27mini. She gone. 1746 with a modded 35 gdsd Capt Team total asalt
Thu Jul 25, 2013 5:46 pm |
brasso
 Re: Got em in!
Tits r stfu
_________________ 1850 Uncle J Delta Performance level 4 GTR
Thu Jul 25, 2013 8:04 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: Got em in!
Gonna look something like this.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
Thu Jul 25, 2013 8:27 pm |
david95
 Re: Got em in!
I'll do it, an bbb can you post a picture of your brackets for the lights cause these ain't got nothing on the side unless I drill a hole through the housing which I don't mind. Thanks.
Thu Jul 25, 2013 8:55 pm |
bbb
 Re: Got em in!
Gotta drill the holes and use washers and lock nuts. I bought the zinc straps from Home Depot and cut them to length.
If you add capacitors to each light, you can run 6 HPS lights with the Honda 2000.
Fri Jul 26, 2013 11:04 am |
bbb
 Re: Got em in!
I also built a ballast box to house all the guts of each light. The housing on those lights is brittle.
Fri Jul 26, 2013 11:12 am |
david95
 Re: Got em in!
Alright I'm starting mine tommorow, thanks a lot for the pictures and info about all of it. What did you make a ballast box out of? I'm guessing plastic conduit boxes.
Fri Jul 26, 2013 6:59 pm |
bbb
 Re: Got em in!
Big Max tool box from Home Depot.
Fri Jul 26, 2013 8:19 pm |
david95
 Re: Got em in!
Sun Jul 28, 2013 7:34 pm |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
 Re: Got em in!
Open up each light and make sure everything is tight. I have seen some econo lights with loose ballast that will cause the housing to bust. I used 1.25x 1/8 aluminum flat bar and made my brackets. If your lights don't have capacitors you can add them to lower amp draw on start up but with that few of lights probably want have a problem. Also make sure to put a little silicon where the bulb and socket come together to keep the bulb from coming loose.
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sun Jul 28, 2013 8:31 pm |
david95
 Re: Got em in!
Finally started messing with it today.
Thu Aug 08, 2013 1:46 pm |
