It is currently Tue Feb 17, 2026 8:14 pm
Reply to topic  [ 15 posts ]
 Trolling Motor Wire
Post Trolling Motor Wire
I have a 17 foot Key west from 97 with all original wires. I am rewiring it and and going to run wires from the back to the front for a trolling motor, what gauge wire should i use for a 12 volt trolling motor?
Mon Jun 30, 2014 8:02 am
Post Re: Trolling Motor Wire
The bigger the better I find. But for that distance I would say minimum of 4gauge. I'm rewiring my 24 volt system after relocating my batteries and I'm going with 2 gauge.
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Mon Jun 30, 2014 8:09 am
You should be fine with 8 gauge wire for a 12 volt set up and that short of a run. It wouldn't hurt to use 6 gauge but in my opinion anything bigger would be a waste of money.
To fish or not to fish? What a stupid question.
17/54 Extreme Hull with a 35GTR with just a basic build.
Mon Jun 30, 2014 2:51 pm
Just re-wired a 18ft Skeeter 56# 24v with 8ga and a 40a breaker. Works better than the 10 that was in it, plus we get better run time out of the batteries. I still can't believe he didn't burn that thing down with 10ga wire and no fuses.
-Custom pool noodle
-stage 4 water wings
Tue Jul 01, 2014 12:24 pm
Alright I'll probably go 8 cause it'll be easier to pull through the boat
Tue Jul 01, 2014 3:32 pm
I guess I just like overkill, haha. I just bought a set of jumper cables and I use that since the wires are together and already color coded
"The internet"
Tue Jul 01, 2014 4:05 pm
Tue Jul 01, 2014 4:18 pm
Would y'all recommend a 12 or 24v system? I'm just worried about the weight
Tue Jul 01, 2014 7:32 pm
Tue Jul 01, 2014 7:34 pm
24 in anything bigger than a mud boat... Or if you troll in rough or fast moving water. The 24v setup will give you longer run time and more power when you need it (if everything else is equal) only down side is that you have to tote and store another battery.
-Custom pool noodle
Tue Jul 01, 2014 8:03 pm
I was checking out the classifieds on the sportsman and there is a few used 24v motors that looked good.
Tue Jul 01, 2014 8:08 pm
Here ya go viewtopic.php?f=32&t=53282
1754GT 35GTR
Tue Jul 01, 2014 8:47 pm
Could I tie the cranking battery into an extra battery or would I need three batteries? I don't know if I have room for 3 batteries
Wed Jul 02, 2014 5:31 am
You could but it's not the right way to go. You really don't want to be draining your starting battery. Also if you are going to go 24volt or parallel 12 volt it's best to have two identical batteries, age and type.
"The internet"
Wed Jul 02, 2014 8:41 am
Wed Jul 02, 2014 8:47 am
