It is currently Thu Feb 19, 2026 8:05 am
2" drain plugs, ice, nearly sank, all's well
Docott
29 degrees this morning around Madisonville. Had drain plug out because it's been raing. A little bit froze in the drain hole. Got to the launch. Actually remembered to put in plug. Thought I had scraped what little bit of ice that was in the hole out. Put plug in. It tightened up and seemed to seal. Launched boat with friend driving. Went to park truck. By the time I got back to the ramp, my friend was frantically yelling at me to come quick! Just as I got there, he barely made it up on the ramp (and, on a canal) before the transom went under! Boat went under all the way to the bottom of the motor (PD 36)!!! He sat his fat ass on the bow on the ramp to keep it from going even further while I unhitched the trailer and got a tow strap attatched to the truck and the boat. We pulled it up further and pulled the plug (it was still in the hole) because, needless to say, the bilge pump hadn't been able to keep up and it would have taken forever to drain now that the boat was safe. I thought for sure my day was down, but the motor cranked right up (it had actually stayed out of the water, so I guess I shouldn't really be surprised). I quess there was still enough ice to keep the plug from seating all the way, it melted once the boat was in the water. I was using plumbing test plugs. Anyone have something better/more secure? Until I find something else, I'm going to put two in each drain hole-one from the inside and one from the outside...and put a burnsamatic in the boat to get rid of ALL of the ice! And I'm going to add a second bilge-still won't keep up, but it'll give me a few precious seconds more time if it ever happens again.
Had a late start, but a good day-a few gw teal, some buffleheads, some dos gris-not the best, but fun.
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
| Sat Dec 22, 2012 2:27 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: 2" drain plugs, ice, nearly sank, all's well
_________________ I gave up mud motors
| Sat Dec 22, 2012 2:43 pm |
Docott
Perfect! Thanks. You really can't torque those plastic plugs tight enough to suit me.
| Sat Dec 22, 2012 2:51 pm |
T-Bubba
| Sat Dec 22, 2012 2:53 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
A builder told me that i shouldn't put those 2 inch plugs in for that reason. My rule 2000 can keep up with one of the standard plugs out.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
| Sat Dec 22, 2012 3:03 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
That's exactly why a big plug is a dumb ass idea
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
| Sat Dec 22, 2012 3:56 pm |
naj
| Sat Dec 22, 2012 4:29 pm |
T-Bubba
they are nice for washing my boat out
| Sat Dec 22, 2012 4:39 pm |
Docott
My friend is.
| Sat Dec 22, 2012 6:23 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
Can't you get a threaded 2" hole and plug? I thought I've seen those in people's photos?
If you can't, I'd likely stick with standard drain plugs.
Sent using my bag phone
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Sat Dec 22, 2012 6:42 pm |
odass
 Re: 2
_________________ Dead Fowl Custom 1954hd with a GTR
| Sat Dec 22, 2012 9:46 pm |
4Cody4
Thought so, that's a good idea right there.
| Sat Dec 22, 2012 10:21 pm |
Docott
That sounds like a good idea. OA-you got a link or can you point me in the right direction? Thanks.
| Sat Dec 22, 2012 10:50 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
| Sat Dec 22, 2012 11:01 pm |
dfou
Docott post a pic of the test plug you're using. You said its plastic?
| Sat Dec 22, 2012 11:02 pm |
Docott
| Sat Dec 22, 2012 11:41 pm |
OwenDickeson
Oncall has a link to some good 2" plugs. PM him
| Sun Dec 23, 2012 6:34 am |
UNCLE-J
We don't use the plastic. We use the galvanized plumbing plugs.
| Sun Dec 23, 2012 6:46 am |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
| Sun Dec 23, 2012 7:17 am |
T-Bubba
 Re: 2
| Sun Dec 23, 2012 7:23 am |
UNCLE-J
You can tighten the FUK out of them.
| Sun Dec 23, 2012 7:31 am |
dfou
| Sun Dec 23, 2012 9:41 am |
Docott
Thanks for the help. I got some 2" oil plugs from autozone for now. They'll be an improvement, while I look into other options.
| Sun Dec 23, 2012 1:55 pm |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
| Sun Dec 23, 2012 2:13 pm |
netman
Joined: Wed Jan 14, 2009 3:48 pm Posts: 2363 Location: Chandler,Indiana
All of us up north guys are laughing at a La guy with drain plug problems. It is 12 degrees outside right now with a foot of snow or more on the ground. I have a jumbo drain hole on my commercial fishing boat. It is about half blocked with ice each and everyday. Add some snow and it makes for a nice start of the day. I do however use the big plugs. One down side is the threads will rust up fairly quick. I have to pound the plug in each morning with my foot. Docott one way I do my frozen plug is I back my boat down into the water with the plug under the water. Water back fills in and then I pull back out letting the water drain. I then scrape whatever ice is left with a knife for that purpose and then pound the rubber plug in with my boot. Right now ice and snow on the ramp is my biggest issue. Our ramps are fairly steep and can make for a dangerous costly launch. I have snow shovels and salt galore in the back of my truck.
_________________ I got a shotgun,rifle and a Go Devil Surface Drive a country boy can survive. 35+hp GDSD engine mods by George Merta 18x48 GDSD boat
| Sun Dec 30, 2012 7:39 am |
chaseh
Joined: Thu Apr 15, 2010 1:50 pm Posts: 1230 Location: Waco, Texas
| Sun Dec 30, 2012 8:02 am |
sas8819
Joined: Sat Oct 15, 2011 8:05 pm Posts: 131 Location: West St. Paul, MN
That's just part of hunting in the north.
Sent from my SPH-D710 using Tapatalk 2
_________________ 1854 Uncle J pushed by a gen 3 PD
| Sun Dec 30, 2012 8:12 am |
UNCLE-J
Hell on all that. My bed is warm..
| Sun Dec 30, 2012 9:23 am |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
| Sun Dec 30, 2012 9:44 am |
OwenDickeson
It was so cold the other morning, my torch didn't want to hardly work....
| Sun Dec 30, 2012 9:56 am |
riverratdm84
Joined: Fri Jul 30, 2010 3:15 pm Posts: 701 Location: pella, ia
| Sun Dec 30, 2012 11:09 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: 2
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Sun Dec 30, 2012 11:34 am |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
My boat was frozen to the trailer so bad this morning that when I got backed in the trailer was floating. Talk about not knowing what the hell was going on, I blamed myself for leaving the straps on the back at first.
| Sun Dec 30, 2012 11:45 am |
UNCLE-J
My azz was frozen to bed. So, I didn't get up
| Sun Dec 30, 2012 11:47 am |
Docott
 Re: 2
| Sun Dec 30, 2012 5:16 pm |
riverratdm84
What else ya gonna do when it 15 deg outside? Sit inside n play video games?
| Sun Dec 30, 2012 6:02 pm |
msm8281
Keep one of those hand held torch thingy in your boat to melt ice if need be
| Mon Dec 31, 2012 7:35 am |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
_________________ 24x60 Dual Prodrives
| Mon Dec 31, 2012 8:42 am |
OwenDickeson
| Mon Dec 31, 2012 10:46 am |
Docott
Nah, Crews, pretty sure it was the ice.
| Mon Dec 31, 2012 11:44 am |
Users browsing this forum: Majestic-12 [Bot] and 1 guest |
