| Cajun anchor http://mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=12078 |
| Author: | POKER1 [ Wed Sep 01, 2010 9:02 am ] |
| Post subject: | Cajun anchor |
Anyone make their own? If so what did you use to make it. Thinking something other than stainless. Not sure where I could get that. |
| Author: | T-Jacques [ Wed Sep 01, 2010 9:19 am ] |
| Post subject: | Re: Cajun anchor |
steel round stock inside of PVC w/caps on ends? Not sure how you'd attach a rope |
| Author: | SmokeEater829 [ Wed Sep 01, 2010 10:00 am ] |
Mine is stainless. I didn't make it myself, but know some people who have. The heavier the bar stock you use the better IMO. Heavier bar stocks allows you to keep the bar shorter. The added weight let's me throw it like spear if the water is deeper than the pole. |
| Author: | cb5331 [ Wed Sep 01, 2010 10:03 am ] |
Yall got pictures of one of these "cajun anchors"? Anything with cajun in front of it just sounds interesting. |
| Author: | forever draggin [ Wed Sep 01, 2010 10:18 am ] |
| Author: | forever draggin [ Wed Sep 01, 2010 10:19 am ] |
I made a few out of aluminum. My stainless one is my h better because of the weight |
| Author: | BASSMASTER [ Wed Sep 01, 2010 10:27 am ] |
| Author: | POKER1 [ Wed Sep 01, 2010 11:04 am ] |
Someone had told me to use the heavier grounding rod from HD or Lowes. I looked at some and the largest seemed to be about 5/8" x 8' long. Its pretty heavy round stock steel coated with brass or bronze. Gonna get me a stick and make a 5' rod to try. It runs about 10.00 a stick. So less than 20.00 per rigged anchor with shackle and 1/4" rope. |
| Author: | Shadow [ Wed Sep 01, 2010 2:44 pm ] |
Thats interesting... never seen that before. |
| Author: | TURBODRIVE [ Wed Sep 01, 2010 4:40 pm ] |
ive got two , 3/4 stainless bout 4 foot long and i have an 8" handle on top with a stainless ring about a foot below the handle that i tie my rope to. Im getting four finished right now and if someone needs one let me know. |
| Author: | forever draggin [ Wed Sep 01, 2010 5:52 pm ] |
They work really well, unless it's super rough |
| Author: | TURBODRIVE [ Wed Sep 01, 2010 6:02 pm ] |
| Author: | dozrya [ Wed Sep 01, 2010 6:52 pm ] |
i read that ppl are using grounding rod. I'm going to go look at that option. I'm trying to talk to Uncle J about building some, but he has too many damn phone calls. |
| Author: | DeathMetalDukk [ Wed Sep 01, 2010 7:48 pm ] |
Aluminum or stainless tube, filled with lead and capped. Never seen one of those before. |
| Author: | earl33 [ Wed Sep 01, 2010 8:16 pm ] |
It would be a Cajun that wants to stick his dick in the mud.... Wonder where the idea got started???? |
| Author: | SmokeEater829 [ Wed Sep 01, 2010 8:23 pm ] |
Don't be so quick to judge Earl. Some of that mud is really soft! |
| Author: | earl33 [ Wed Sep 01, 2010 8:25 pm ] |
| Author: | cb5331 [ Wed Sep 01, 2010 8:26 pm ] |
I'm guessing these would not work to well on a hard bottom, huh? |
| Author: | POKER1 [ Wed Sep 01, 2010 8:30 pm ] |
| Author: | POKER1 [ Wed Sep 01, 2010 8:32 pm ] |
I picked up a 5/8" x 8' grounding rod and a stainless shackle from Home Depot for 15.00. If 4' is enough you could make 2 w/shackles for less than 20.00. Its copper coated so rust should be at a minimum and its really stout so it should work fine. |
| Author: | Shadow [ Wed Sep 01, 2010 8:44 pm ] |
| Author: | cb5331 [ Wed Sep 01, 2010 8:45 pm ] |
Find an Ace Hardware. They cram everything into those lil ass stores... |
| Author: | POKER1 [ Wed Sep 01, 2010 8:55 pm ] |
| Author: | HUNT4DEER [ Wed Sep 01, 2010 8:55 pm ] |
you get the mud itch on your crank and wish you could get the balls up to cut it off to get it to stop itchin. |
| Author: | SmokeEater829 [ Thu Sep 02, 2010 3:40 am ] |
Look, the mud itch ain't as bad as some of the things you can pick up on a night in the French Quarter. At least the mud itch goes away on it's own. And it'll never track you down for child support! Just sayin! |
| Author: | POKER1 [ Fri Sep 03, 2010 9:00 am ] |
Made this one 5' long. Never used one before so I didn't want to go to short. That is a 1/4" stainless shackle. 1' PVC holder for the boat. |
| Author: | BROOKS [ Fri Sep 03, 2010 9:09 am ] |
Pokers ~ You need to paint the fence and mows the yard ...... just sayin' ....... |
| Author: | POKER1 [ Fri Sep 03, 2010 9:54 am ] |
Hahaha. Yard is mowed and I don't care if that fence ever gets painted. That's Jo's job and I keep telling her the same thing. |
| Author: | BayouStateHunter [ Fri Sep 03, 2010 1:07 pm ] |
Daddy built me a couple from stainless bar with a washer welded on top. Hate the noisy shackles for fishing. It's F'in heavy but works much better then the alums. |
| Author: | HUNT4DEER [ Fri Sep 03, 2010 9:14 pm ] |
im guessin its the redneck equal to a power pole ? |
| Author: | POKER1 [ Sat Sep 04, 2010 8:58 pm ] |
The CA worked great. Need to make a second one to hold from 2 points. Easy to use and held great in pretty good wind today. It holds with a short line too so no need for long ropes. |
| Author: | DuramaxDR3W [ Thu Mar 10, 2011 1:04 am ] |
another reason I love this site! was bout to drop some money on a cajun anchor and thought to myself... "that's a simple design im sure the guys on MMT have found a way to make a homemade one" sure enough 1 search for a cajun anchor and I find this! good stuff Poker!! gonna make me a couple tomorrow at work, we got 3/4" x 10' ground rods! |
| Author: | Nathan [ Thu Mar 10, 2011 11:46 am ] |
I make my own stick-it style pins using 3/4" fiberglass rods from Grainger. I generally cut them to 8' and make a T-handle out of 2x2 vinyl trim. A little glue, a stainless pin to hold the handle on, and some sanding is all it takes to make one. Nathan |
| Author: | autogateman [ Thu Mar 10, 2011 1:05 pm ] |
do you think the cajun anchor would hold in the mud if i tried to winch off of it? |
| Author: | dog walker [ Thu Mar 10, 2011 1:24 pm ] |
| Author: | slingshot [ Thu Mar 10, 2011 6:44 pm ] |
My x girl friend would like one of them anchors , she ain't gots no boat. |
| Author: | slingshot [ Thu Mar 10, 2011 6:49 pm ] |
