It is currently Sun Jun 29, 2025 3:55 pm
[ 9 posts ] |
Sko
 AR upper
I just bought a bushmaster AR 223. It has the upper with the handle. Where a good place to get a upper with the slide for a scope? Thanks for info
_________________ 18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Fri Oct 14, 2011 2:19 pm |
Richard in LA
Joined: Tue Sep 08, 2009 1:58 am Posts: 282 Location: Prairieville, LA
 Re: AR upper
You are looking to change out a carry handle upper for a flattop, or looking for a complete barreled upper? You have 2 options to just change the upper receiver itself, buy a stripped flattop (A3) upper and reuse your existing forward assist assembly and ejection port door/spring/shaft (these range from $60-70) or you can buy an upper with them already installed for $90-100. It's not very hard to swap them out, but you do need at the very minimum a good armorers wrench, and I'd highly recommend an upper reciever vise block. although I have successfully changed them without one, You run the risk of cracking the upper reciever on the thin lower portion of the ejection port, along with marring up the finish on the upper itself. I'd check out Spikestactical.com, PalmettoStateArmory.com & AIMsurplus.com. They all have good quality parts, and I have bought from all 3, excellent companies to do business with. I don't see where you are located, but If you are close, I can change one out in about 10-15 minutes.
_________________ GTR, Waitin' on a DFOU hull
Fri Oct 14, 2011 3:07 pm |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
 Re: AR upper
Richard..... Does head spacing issues come into play when changing the upper receiver (not the complete upper)?
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
Fri Oct 14, 2011 9:24 pm |
Richard in LA
 Re: AR upper
No. The bolt headspaces inside the barrel extension, and swapping out just the upper is not a concern, since you are still using the same bolt & barrel.
Fri Oct 14, 2011 10:54 pm |
BayouStateHunter
 Re: AR upper
Sat Oct 15, 2011 7:08 am |
Sko
 AR upper
Sat Oct 15, 2011 8:12 am |
THE TANK
Joined: Wed Mar 04, 2009 7:34 pm Posts: 1080 Location: Coteau Homles, La
 Re: AR upper
Sat Oct 15, 2011 2:08 pm |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
 Re: AR upper
check out bravo company. That's where I got myA3 upper when I swapped.
_________________ Sometimes it's best to just keep your fingers quiet...
Sat Oct 15, 2011 4:27 pm |
hunt682
Joined: Tue Jan 27, 2009 9:43 am Posts: 1127 Location: Camilla, Georgia
 AR upper
Sat Oct 15, 2011 5:35 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 44 guests |
