It is currently Sun Jun 29, 2025 7:10 pm
Reply to topic  [ 9 posts ]
 AR upper
Post AR upper
I just bought a bushmaster AR 223. It has the upper with the handle. Where a good place to get a upper with the slide for a scope? Thanks for info
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Fri Oct 14, 2011 2:19 pm
Post Re: AR upper
You are looking to change out a carry handle upper for a flattop, or looking for a complete barreled upper? You have 2 options to just change the upper receiver itself, buy a stripped flattop (A3) upper and reuse your existing forward assist assembly and ejection port door/spring/shaft (these range from $60-70) or you can buy an upper with them already installed for $90-100. It's not very hard to swap them out, but you do need at the very minimum a good armorers wrench, and I'd highly recommend an upper reciever vise block. although I have successfully changed them without one, You run the risk of cracking the upper reciever on the thin lower portion of the ejection port, along with marring up the finish on the upper itself. I'd check out Spikestactical.com, PalmettoStateArmory.com & AIMsurplus.com. They all have good quality parts, and I have bought from all 3, excellent companies to do business with. I don't see where you are located, but If you are close, I can change one out in about 10-15 minutes.
GTR, Waitin' on a DFOU hull
Fri Oct 14, 2011 3:07 pm
Post Re: AR upper
Richard..... Does head spacing issues come into play when changing the upper receiver (not the complete upper)?
Fri Oct 14, 2011 9:24 pm
Post Re: AR upper
No. The bolt headspaces inside the barrel extension, and swapping out just the upper is not a concern, since you are still using the same bolt & barrel.
Fri Oct 14, 2011 10:54 pm
Post Re: AR upper
Sat Oct 15, 2011 7:08 am
Post AR upper
Sat Oct 15, 2011 8:12 am
Post Re: AR upper
Sat Oct 15, 2011 2:08 pm
Post Re: AR upper
check out bravo company. That's where I got myA3 upper when I swapped.
Sometimes it's best to just keep your fingers quiet...
Sat Oct 15, 2011 4:27 pm
Post AR upper
Sat Oct 15, 2011 5:35 pm
Users browsing this forum: No registered users and 40 guests
