Woodiebuster
 Driving posts in the mud.
I am building a blind in the woods, its gunna be 12x5 and about 4' off the ground.
How can I drive the posts in the mud? There is a thin layer of grass and roots but after that, I could shove a pipe as far down as I wanted. I had thought about bringing a pump and washing a hole out for the posts but the water is so shallow and grassy I could never keep it running.
We had some shitty 4x4's for our posts and when we tried to drive them with a sledge they just busted.
Just wondering how some of yall do it...
Tue Oct 11, 2011 3:52 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: Driving posts in the mud.
Cutting the ends at a point will help you out
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Oct 11, 2011 4:26 pm |
Woodiebuster
We did that, we just need a way to keep them from sinking further down all the time.
Thinking about digging holes and sticking a peice of 6" PVC with a cap on the bottom in it then putting the post and sac-crete in there.
How far down would yall drive them? 4'?
Tue Oct 11, 2011 4:29 pm |
Beadlejuicejr
Best way to keep them from going further is make a pad around the poll after it's drove to make a bigger surface area
Tue Oct 11, 2011 4:37 pm |
Woodiebuster
We thought about that too, like take a 2x4 and nail it to all the posts on that side right above the mud?
I guess my question is, what is the easiest way to get them in the ground and not split the board hitting it (thought about a steel cap made with a plate and square tubing to slide over it)
Tue Oct 11, 2011 4:49 pm |
jakecologne
Joined: Thu Jun 10, 2010 2:57 pm Posts: 933 Location: Des Allemands
If it's in the woods you can't frame it up on trees? Instead of driving post?
_________________ 16x44 Hanko Skiff 35GTR
Tue Oct 11, 2011 4:59 pm |
Woodiebuster
Its just small buckbrush in the hole, if you got out to the trees on the bank you would be 40 yards from the hole.
Tue Oct 11, 2011 5:06 pm |
jakecologne
Oh I see. I would personally give it a surface to sit on so it doesn't sink. Like you said the 2x4s around the bottom where it's flush with the mud
Tue Oct 11, 2011 5:08 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Tue Oct 11, 2011 5:32 pm |
pokey79
u need a ***** head for driven them down!!! http://www.kencove.com/fence/T-Post+Dri ... il_TPR.php heres an example!!
pokey79
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
_________________ 18x48 Charles Leonard / 36PD
Tue Oct 11, 2011 6:08 pm |
Woodiebuster
So, you think having it 4 feet in the mud will be enough?
Tue Oct 11, 2011 6:14 pm |
POKER1
Tue Oct 11, 2011 6:20 pm |
SP
Pour a footer on the bottom. Dig a hole, drive the support into the ground, and pour some ready mix concrete to secure it. Should distribute the weight and hold it there....
Tue Oct 11, 2011 6:34 pm |
Woodiebuster
There is about 6" of water over it right now... That sac Crete won't set will it?
Tue Oct 11, 2011 6:39 pm |
SP
Tue Oct 11, 2011 6:52 pm |
trev93
Joined: Sun Mar 15, 2009 5:48 pm Posts: 222 Location: Walker, LA
A lot of guys i know put the post in a 5 gal bucket then fill the bucket with sac crete and just set it on the bottom.
_________________ 37 EFI Prodrive pushing a 1748 Tim's Marine Custom Flat
Tue Oct 11, 2011 7:04 pm |
meterman3
6" square tubing with handles weld plate on 1 end use it like a t post driver
_________________ driving a gd in ur lake and i aprove this message
Tue Oct 11, 2011 7:31 pm |
rebbeer
Joined: Thu Feb 05, 2009 7:39 pm Posts: 417 Location: Lafayette, LA
_________________ 35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
Tue Oct 11, 2011 7:41 pm |
POKER1
Tue Oct 11, 2011 7:43 pm |
rebbeer
Tue Oct 11, 2011 8:11 pm |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
Tue Oct 11, 2011 8:13 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Rent a gas auger
_________________ 1850 & 36pd
Tue Oct 11, 2011 8:34 pm |
MaXXis85
When we put up carports, I use a 5" square tubing rammer we call a "mother in law" Mofo will whoop you but I reccomend doing like willet said.. Pund them in the ground 2'+ and your good or till you can't pound them any further. Then do like Poker1 said about theboard on the mudline to help stop it from sinking.
Wed Oct 12, 2011 5:49 am |
basinlover
Joined: Mon Mar 09, 2009 12:24 pm Posts: 279 Location: DE Jeanerette, LA.
acuually in the marshy areas like that all you need is a good 1/2 drill cordless with a plant bit like they use to put ferns and shit in at lowes to break the surface then tie the post together at the surface after with 2x4's.
_________________ There is no replacement for displacement!!!!
Wed Oct 12, 2011 8:33 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
We call it a widow maker at work. but a pile driver made of 6" pipe that's 24" long with handles will keep you in shape. Cap one end so that it rest on the post. The other contraption is what we call teeth. Basicly a clamp that bolts to the post so that you can shimmy up the post to get the pile driver on top. takes two people to do this one to hold the post while the skinny one in the group climbs up and jumps on the clamps till the widow maker is needed. Then the fun begins. Enjoy.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Wed Oct 12, 2011 9:03 am |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Don't know how soft your mud is but down in the marsh we jet our pilings in. Basically a water pump attached to a long metal pipe that shoots water out of it like a jet. But you're gonna go a lot deeper than 4 feet.
Wed Oct 12, 2011 11:18 pm |
Woodiebuster
Wilson... Refer to first post.
We thought about that and we could do that easiest but the water is shallow and the floaton is thick.
Thu Oct 13, 2011 6:28 am |
Wilson
No water close by that you could run a hose to?
Thu Oct 13, 2011 12:15 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Bring a drill and a good sized auger bit, break through the roots and the post will go right in. Once you get the posts the depth you want them. nail a board across all of them at ground level. This will tie them all together for strength, plus keep the individual posts from sinking any further.
_________________ Put yer face in the myrtles.
Thu Oct 13, 2011 12:48 pm |
Da-Cajun-Angla
_________________ cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Thu Oct 13, 2011 12:57 pm |
Thog13
do yall leve the post flat on bottom or do yall cutem at a angle? i always heard leave them flat
_________________ 1432 and needs a longtail!!
Thu Oct 13, 2011 5:50 pm |
HH_Kennels
Joined: Sun Jul 17, 2011 4:55 pm Posts: 181 Location: Mineola, Texas
leave the post flat cut on the end, if you have water there where you are trying to set the post, figure out where you want it. set the post up and just work the post vertically up and down and it should go down as far as you want, when you pull the post up a little it sucks water to the bottom then when you push the post down it hydraulics and washes out the mud underneath, i have built 10 blinds in all different bottom types using this method. about three foot deep is all you need for a sturdy base. I set 6 post for a 4x8 blind and never had a post go soft or sink once you get them braced in by building the blind on top.
Thu Oct 13, 2011 6:32 pm |
B-RAD1
Joined: Tue Sep 13, 2011 1:27 pm Posts: 58 Location: Saint Amant
We've built many platforms in the swamp. We cut a point on the 4 x 4 and use a 48" pipe wrench. Open the jaws so that it will fit around around the side 4 x 4 fairly snug and stand on the handle n slightly bounce on it till you get the desired depth. Make sure you put a short 2 x across the bottom to prevent it from sinking deeper.
Thu Oct 13, 2011 7:02 pm |
beauxabby
Joined: Tue Nov 09, 2010 9:38 pm Posts: 63 Location: Clear Lake TX
Thu Oct 13, 2011 7:14 pm |
POKER1
Damn yall have made driving a board into the ground a cluster. Its a board, whack it a few times with a hammer and call it good...........
Thu Oct 13, 2011 7:22 pm |
Woodiebuster
Ive got 6 posts... I should be able to try most of the ways once
Thu Oct 13, 2011 7:32 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
Thu Oct 13, 2011 8:40 pm |
MaXXis85
Fri Oct 14, 2011 6:27 am |
