It is currently Fri Feb 20, 2026 10:13 pm
Reply to topic  [ 25 posts ]
 Mallard machine ?
Post Mallard machine ?
Saw some posts about MM in another thread. To those of you who use them...
How effective do you find them? As good as the mojo before the ducks learned what they were?
When/under what conditions is the MM most effective? When is it less affective?
Do you think it works better than a jerk line enough to make it worth the extra trouble?
Has anybody made their own? It would be simple to do. I've seen some people have on YouTube. It would save some money-especially if you had and old troller or could get one cheap.
Thanks.
Spence
Thu Dec 06, 2012 4:31 pm
Post Re: Mallard machine ?
I just started looking into that this morning, I've got a 30# thrust trolling motor i picked up at a garage sale. I can't decide if its worth trying to build an ice eater or turn it into a mallard machine.
Every day I'm paddlin'
Thu Dec 06, 2012 5:48 pm
they are a pain in the ass to build, pain in the ass to put out and pick up every time. If you don't leave your decoys don't bother. I will buy trolling motors thou
Thu Dec 06, 2012 6:39 pm
Jerk rig....
HOTSAUCE170 wrote:
Thu Dec 06, 2012 7:11 pm
Thu Dec 06, 2012 8:01 pm
Thu Dec 06, 2012 8:25 pm
Looks like I already got it
Thu Dec 06, 2012 8:31 pm
Ddb would have first dibs...
Thu Dec 06, 2012 8:36 pm
Boom
Thu Dec 06, 2012 8:37 pm
Dammit!
Thu Dec 06, 2012 9:11 pm
There a pain in the ass to set out and pick up... Jerk rig works just as well for a hell of a lot cheaper and much simpler...
1748 WC Custom 27 mini
Thu Dec 06, 2012 9:59 pm
Thanks. How many decoys do you usually usually put on a single jerk line?
Do you just use a small anchor on the far end? I've heard of attaching a bungee cord to the anchor and then the line to it. Is that worth it? Do you worry about then line coming out off the water when you pull it? I thought about using another small anchor near the boat/blind and running the cord through it like a pulley.
Thu Dec 06, 2012 11:03 pm
200 u fukn idiot
Thu Dec 06, 2012 11:06 pm
Alrite I'll quit being an ass some people seem to have so much edumacation but no common sense docott it's so simple u don't need a set of plans go to the hardware store buy a 6 ft piece of steel 3/8 put it in the hitch of ur truck bend about 6 inches of it into a 90 for a handle to shove in ground but a roll of green 1/4 in mainline attach to steel bar buy the longest bungee u can find attach to pole pull slack in main line and tie bungee in get the little copper flare fittings that are for flaring copper tubing and run down mainline where u want decoy squeeze with pliers run a big snap swivel to crimped flare fitting then run another one down and crimp for each place u want decoy usually 7 at the most then find a nice fiberglass shovel handle with rubber grip drill hole and insert line and tie knot and booyah u have a jerk rig
Thu Dec 06, 2012 11:23 pm
Thank you AKA :)
Thu Dec 06, 2012 11:29 pm
But honestly it's a pain in the ass to set up every time too unless u r hunting in flooded timber and are wading in and out
Thu Dec 06, 2012 11:38 pm
Fri Dec 07, 2012 12:20 am
I'll do what I have to to keep my digits.
Fri Dec 07, 2012 12:27 am
I took my mm and used the battery pack from ahigdon pulsator .plugs right in and automatically cycles like the higdon. Makes it a lot easier than running cords to blind
Fri Dec 07, 2012 7:06 am
Duckthang,I've hunted over these for three years and they are bad ass. My buddy is the builder. They back their product 100%.
1852 Phowler Extreme w/ 36PD
Fri Dec 07, 2012 10:40 am
My jerk string always gets tangled and clusterfukked in the weeds and grass and nobody ever wants to pull on it plus the ducks might spot you.
I've started rachet strapping a trolling motor to a stump in the decoy spread with a small 4 wheeler/motorcycle battery hooked to it and leave it on a low speed all morning that way there are ripples on the water continuously.
Fri Dec 07, 2012 10:58 am
I had a similar idea, Woodie. Hunting out of boat blind-small transom mount trolling motor mounted on the gunnel facing decoys. flip the controls around so they're in the boat and you could even control speed and direction.
Fri Dec 07, 2012 12:58 pm
Fri Dec 07, 2012 4:22 pm
Fri Dec 07, 2012 8:18 pm
Academy and rig em right make really nice jerk rig set ups for less than 30 dollars
Sun Dec 09, 2012 2:26 pm
