Got em in! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=43395 |
Author: | david95 [ Thu Jul 25, 2013 1:51 pm ] |
Post subject: | Got em in! |
Put in a order last Friday for 4 150s from econolite and got them in today. Gonna start the deck tomorrow already got the material for it. Can't wait to test em out. Sent from my DROID RAZR using Tapatalk 2 |
Author: | slingshot [ Thu Jul 25, 2013 5:46 pm ] |
Post subject: | Re: Got em in! |
Post some pic up when ya done wit it. |
Author: | brasso [ Thu Jul 25, 2013 8:04 pm ] |
Tits r stfu |
Author: | bbb [ Thu Jul 25, 2013 8:27 pm ] |
Gonna look something like this. |
Author: | david95 [ Thu Jul 25, 2013 8:55 pm ] |
I'll do it, an bbb can you post a picture of your brackets for the lights cause these ain't got nothing on the side unless I drill a hole through the housing which I don't mind. Thanks. Sent from my DROID RAZR using Tapatalk 2 |
Author: | bbb [ Fri Jul 26, 2013 11:04 am ] |
Gotta drill the holes and use washers and lock nuts. I bought the zinc straps from Home Depot and cut them to length. If you add capacitors to each light, you can run 6 HPS lights with the Honda 2000. |
Author: | bbb [ Fri Jul 26, 2013 11:12 am ] |
I also built a ballast box to house all the guts of each light. The housing on those lights is brittle. |
Author: | david95 [ Fri Jul 26, 2013 6:59 pm ] |
Alright I'm starting mine tommorow, thanks a lot for the pictures and info about all of it. What did you make a ballast box out of? I'm guessing plastic conduit boxes. Sent from my DROID RAZR using Tapatalk 2 |
Author: | bbb [ Fri Jul 26, 2013 8:19 pm ] |
Big Max tool box from Home Depot. |
Author: | david95 [ Sun Jul 28, 2013 7:34 pm ] |
Author: | missile [ Sun Jul 28, 2013 8:31 pm ] |
Open up each light and make sure everything is tight. I have seen some econo lights with loose ballast that will cause the housing to bust. I used 1.25x 1/8 aluminum flat bar and made my brackets. If your lights don't have capacitors you can add them to lower amp draw on start up but with that few of lights probably want have a problem. Also make sure to put a little silicon where the bulb and socket come together to keep the bulb from coming loose. |
Author: | david95 [ Thu Aug 08, 2013 1:46 pm ] |
Finally started messing with it today. Sent from my DROID RAZR using Tapatalk 2 |
