It is currently Mon Jun 30, 2025 3:41 am
Reply to topic  [ 5 posts ]
 Generator and battery charging clarification
Post Generator and battery charging clarification
I'm a newbie to the whole thing. i built a deck on my boat with 7, 500watt work lights. Running a 5500watt brigs generator. Id like to know what exactly i would need to charge my trolling battery. With that said could i charge 2 batteries, i have one for my running lights and light bar.
So what exactly do i need to do this? Thanks
Tue Jan 21, 2014 8:32 pm
Post Re: Generator and battery charging clarification
Look into a power max or iota convertor. Depending on the size trolling motor u run depends on what amp convertor and if it's 12volt or 24 volt. Get you one of them and you will never have to worry about your battery dieing
Tue Jan 21, 2014 9:53 pm
Used to run a powermax 55 amp on a 12 volt troller could run all night long on one battery. Powermax was a little cheaper.
Wed Jan 22, 2014 10:09 am
i have a 55lb rip tide, its a 12 volt. So i should get the convertor and thats it? what about wiring? pretty simple?
Fri Jan 24, 2014 1:22 pm
Yes it's real simple. Wires from trolling motor to battery. From battery to convertor. Convertor to generator. Run ur trolling motor for a few hours then plug in your convertor and keep fishing
Fri Jan 24, 2014 5:57 pm
Users browsing this forum: No registered users and 43 guests
