It is currently Sat Jul 18, 2026 2:57 am
Reply to topic  [ 28 posts ]
 Bowfishing lights
Post Bowfishing lights
What are the best bowfishing lights that are not very expensives. I just dont want to buy cheap lights and wont last.
Fri Mar 28, 2014 4:47 am
Post Re: Bowfishing lights
Seelite. 50 watt 12/24 volt
Fri Mar 28, 2014 9:05 am
Halogen. Shop work lights. $10-12 and will last years
17x48 extreme stage 2 GTR
Fri Mar 28, 2014 9:19 am
Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Fri Mar 28, 2014 9:25 am
Thoughts on these?
http://www.ebay.com/itm/10x-27W-12V-24V ... 5a&vxp=mtr
Fri Mar 28, 2014 9:50 am
Fri Mar 28, 2014 4:13 pm
RPM bowfishing has good led and great customer service
Fri Mar 28, 2014 7:10 pm
I'm guessing these are the same as the square shaped 27watt everyone is using?
Fri Mar 28, 2014 7:16 pm
Fri Mar 28, 2014 8:27 pm
VooDoo--what you get when you leave your Voo outside all night long.
Fri Mar 28, 2014 8:46 pm
17x54 Extreme Pushed By A Gtr 35 Stage 2 Done ByJamieB Baw!
Nut Up Or Shut Up
Fri Mar 28, 2014 9:32 pm
Fri Mar 28, 2014 9:33 pm
Yep keep them dry and they are good. Cheap to buy also
Sat Mar 29, 2014 7:44 am
One thing. I love my led lights. As for as them being better than other lights they are not. But they are easy to maintain and you don't have to deal with fucking generators
Sat Mar 29, 2014 7:45 am
Thanks for the replies fellas. I already have a Honda 2000 ginny for other things. I may just try the shop light idea to save some money. I figure put 2- 250 watt lights on each side and 2 in front for a total of 6. 1500 total watts of lights, should be fine with that generator. Hopefully the cash will be there in a few months to get a platform like I want built.
Sat Mar 29, 2014 9:42 am
Sat Mar 29, 2014 11:20 am
Sat Mar 29, 2014 11:38 am
the color temp on them is 6000-6500k whatever that means
Sat Mar 29, 2014 11:41 am
Those are spot you need flood
Sat Mar 29, 2014 11:44 am
I was going to try these from eBay.
50w led, 12v, warm temp
Bundle of 10 for $500 ($50 ea)
http://bit.ly/1mfToHy
They also available in yellow color. Never seen that before.
[Stage 2.5]
Sat Mar 29, 2014 12:05 pm
Sat Mar 29, 2014 12:11 pm
Ok, have to ask,
More coverage and more output is what you want right? If you get LED's that are only 50 Watts, you would have to put quite a few to get good coverage and bright enough right? So if you put 5 on each side, you still only have effective about 250 watts.
Or do LED's put out more lumens with 5X's 50 watts, as a 250 watt halogen. Trying to get this to an apples/apples comparison. True, no need for a generator the low power consumption, but the cost is a lot for LED's if you already have a generator and mount shop lights.
Where is my thinking wrong here?
Sat Mar 29, 2014 12:13 pm
[Stage 2.5]
Sat Mar 29, 2014 12:17 pm
I bought 8x50w LED'S @5000 Lumens a piece shipped to my door was around $850. Only thing im not satisifed with is the mounting brackets they csme with, I feel for the money I paid for them the mounting brackets should be much more durable and stout, as fsr as the lights themselves, they are rock solid and bright as hell
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sat Mar 29, 2014 1:10 pm
For the led lights should you buy the warm white led lights or the cool white or is there any difference?
Sun Mar 30, 2014 10:51 am
Sat Apr 19, 2014 7:40 am
Here is the solution you seem to be looking to eliminate LED reflection as I see many people posting about tinting thier leds. Ive had tint wear out and a pain to remove when you want the white light back for clear waters. Goto ebay and type in "Carplite" in the main search box. They sell HPS or Green colored filter covers for 50W LED lights. Also have Custom sizes if needed for other types of light frame sizes. I used them and made a world of difference. I bought one at first just to try out and bought ten after that. Got the best worlds of using LEDs with the color of HPS to better penetrate the water and reduce glare. They are made from transparent plexiglass so much much more durable than tint/film. And you can easily remove these in seconds if you want the bright light back for clear water. Much cheaper alternative than going HPS with all the extra bulbs, capacitors, genny, difficult wiring and weight, etc. Hope this helps, just wanted to share what I have found to everyone who had the same issues I had.
Here is the link:
http://www.ebay.com/sch/i.html?_from=R4 ... e&_sacat=0
Fri Dec 30, 2016 8:14 am
Some more pics below
Fri Dec 30, 2016 8:20 am
