Choke tubes http://mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=5743 |
Author: | backwaterballer [ Fri Oct 30, 2009 10:17 am ] |
Post subject: | Choke tubes |
What choke tubes do you guys think is best for shooting ducks in open water. |
Author: | Rail [ Fri Oct 30, 2009 10:23 am ] |
Post subject: | Re: Choke tubes |
Same one for the timba; FULL.. You either kill em or they fly away but you don't sail near as many as shooting an IC (or similar) choke.. In the timba you can here the fethers rippin off.. ![]() |
Author: | backwaterballer [ Fri Oct 30, 2009 10:36 am ] |
That's what I shoot kinda thinkin about going to an extended full |
Author: | richardb [ Fri Oct 30, 2009 11:25 am ] |
I shoot a O/U and use a Full & Mod. |
Author: | earl33 [ Fri Oct 30, 2009 12:16 pm ] |
Patternmaster. I kill Doves, Ducks, and Geese with it, Bout $100.00 but the best choke i ever owned. check out thier wed site... Here is a picture of a teal that got a little to close... |
Author: | 3rd Coast Killer [ Fri Oct 30, 2009 1:09 pm ] |
My Kicks Hi-Flyer shoots like a dream. I have a Full in my Nova and will never shoot anything else at ducks. Dense pattern and slight reduction in felt recoil. What more could you ask for? I have shot a pattern master as well, and like both but for the $$$ savings I choose the kicks. |
Author: | deltaduckmaster [ Fri Oct 30, 2009 7:19 pm ] |
I love the briley ducks passing i think its a mod. |
Author: | WestEndAngler [ Fri Oct 30, 2009 7:23 pm ] |
Author: | Da-Cajun-Angla [ Fri Oct 30, 2009 8:19 pm ] |
ive always been told u cant use full on steel, only modified...am i misinformed? ![]() |
Author: | LA OUTLAW [ Fri Oct 30, 2009 9:23 pm ] |
I shoot a carlson's MOD. Extended..Works for me!! the $$$ wasn't to bad either |
Author: | earl33 [ Sat Oct 31, 2009 6:41 am ] |
Author: | Burch [ Sun Nov 01, 2009 8:53 am ] |
I shot steel out of my 1100 full for years and then had it cut down and screw in chokes put in.The gunsmith told me I could shoot steel for years and be ok or the next time I pulled the trigger I could ring the barrel.Its a crapshoot,but now I use a patternmaster and like it. |
Author: | Rail [ Sun Nov 01, 2009 4:12 pm ] |
Author: | Wilson [ Sun Nov 01, 2009 10:42 pm ] |
I used to shoot modified out of my old Beretta 390 with a 28" barrel and really liked it. I bought a case of Winchester Supreme #2's (the expensive stuff) one time and shot better than I ever have. I have since replaced that gun with a Beretta Xtrema 1 with a 26" barrel. I usually use a modified choke and shoot OK with the cheap or midrange shells like Xperts or Kent #2 1550 FPS. I bought another case of the Supreme's thinking that they would be great and I couldn't hit the broadside of a barn. I'm not sure if my gun just doesn't like them or what. I seem to shoot much better during teal season when I put in my improved cylinder choke and shoot #4's. I don't really want to shoot that choke or shot size during the regular season because I am scared of too many cripples, but I will give the IC choke a try using the Supreme's during big duck season just to test it out (since I still have half a case). What shot size do y'all use and does anyone use improved cylinder? I have been looking at the Briley Decoy Choke that Cabelas sells (see link below) to see if that helps at all. I think it's constriction is between IC and modified. Has anyone used this choke? If the Briley doesn't help, I might have to stick with the cheap shells. Most of my shots are decoying birds in the marsh anywhere from 15-40 yards. It seems that most of yall are using a fuller choke than I'm used to but I would like any recommendations for an aftermarket choke around a modified constriction. I would also like y'alls opinion on how different shells pattern in different chokes. Thanks http://www.cabelas.com/cabelas/en/templ ... ISO-8859-1 |
Author: | hatchie rat [ Mon Nov 02, 2009 10:21 pm ] |
i shoot a kicks high flyer. i love it n will never shoot anything else. well worth the money. |
Author: | coastal [ Mon Nov 02, 2009 10:28 pm ] |
I shoot a Briley Full Goose all season long.It will kil'em way out there.You have to be a good shot when they are close. |
Author: | misfire [ Thu Nov 12, 2009 6:41 am ] |
I am shooting a Rhino light mod. But the way I shoot, who knows how well the tube works ![]() |
Author: | earl33 [ Fri Nov 13, 2009 8:20 pm ] |
Coastal....... I want to hunt with you...... |
Author: | Mud Slinger [ Mon Nov 16, 2009 11:02 pm ] |
these are great choke tubes really put a hurtin on some snows last spring with it http://www.angleport.com/xtremerangewat ... p?C=275072 |
Author: | coastal [ Tue Nov 17, 2009 2:53 pm ] |
Author: | richardb [ Tue Nov 17, 2009 3:40 pm ] |
Look at your deck hands ![]() |
Author: | grrifles [ Tue Nov 17, 2009 4:54 pm ] |
X2 on the angle port tubes I have a full set for my sbe2 and they pattern my handloads very well. |
Author: | jpc014 [ Wed Nov 18, 2009 5:35 pm ] |
