| 300blk http://mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=61697 |
| Author: | Walkers Bay Synd [ Sat May 09, 2015 7:30 pm ] |
| Post subject: | 300blk |
I'm looking to build an upper in 300blk for plinking and maybe a bit of hunting. Would doubt it will get used past 200yards. The question is how short is too short barrel wise. Bearing in mind your SBR rules don't apply, I only need to retain 30 inchs OAL. |
| Author: | Russ [ Sat May 09, 2015 8:09 pm ] |
| Post subject: | Re: 300blk |
Any lengths would be fine. The 16" are capable of accuracy to 600, so as long as the rifle handles well, you'll probably be fine with any lengths you can get a hold of in that chamber. |
| Author: | KD [ Sat May 09, 2015 8:29 pm ] |
Check out 300blktalk.com, all the information you'll ever need there. Personally, I've killed out to just over 100 yds with 8" barrel and 110gr Barnes black tips. |
| Author: | Walkers Bay Synd [ Sat May 09, 2015 9:13 pm ] |
| Author: | netman [ Sun May 10, 2015 1:21 am ] |
Walker think about the 458 SOCOM. Real thumper and very suppressor friendly. I really like mine. I have dropped some really nice deer with it. |
| Author: | Walkers Bay Synd [ Sun May 10, 2015 4:47 am ] |
| Author: | micahb [ Sun May 10, 2015 5:44 am ] |
I killed 2 last year with my 8.5" at 200yds with a 130gr horned lead tip. |
| Author: | Russ [ Sun May 10, 2015 9:43 am ] |
That 450 hits like a hammer, on both ends. Not what I would consider ideal for anything other than killing someone threatening my life. It's shootable, but not pleasant at all for more than a handful of shots. |
| Author: | micahb [ Sun May 10, 2015 9:48 am ] |
I can not confirm nor deny if I killed both of these Deer and no it wasn't dark when I may or may not have shot them running at 200yds |
| Author: | Walkers Bay Synd [ Sun May 10, 2015 8:47 pm ] |
| Author: | micahb [ Mon May 11, 2015 2:50 am ] |
| Author: | Buddy [ Mon May 11, 2015 4:32 am ] |
| Author: | Walkers Bay Synd [ Mon May 11, 2015 4:58 am ] |
| Author: | Buddy [ Mon May 11, 2015 5:05 am ] |
| Author: | Walkers Bay Synd [ Mon May 11, 2015 5:12 am ] |
What area. There's only about 3 degrees of separation in this place. |
| Author: | Bigrich [ Wed May 13, 2015 1:34 am ] |
I don't have any photos with mine on my phone, but when I get back home I will post. Mine is 8.250 barrel with a Samson 15" rail. When I put my can on only have an inch hanging out the hand rail. |
| Author: | Walkers Bay Synd [ Wed May 13, 2015 1:55 am ] |
| Author: | Bigrich [ Wed May 13, 2015 2:26 am ] |
That's good thing about the Samson rail it's not a quad so no 1913 rails all over the place just the top. I use to like the quads but the last 5-6 rails I have gotten away from them myself. Main reason is the width of them, just like the slim rails better! I should be able to post a picture this weekend for ya. |
| Author: | Russ [ Wed May 13, 2015 6:37 am ] |
Check out Midwest industries handguards. Can get a tube and add only the rails you want. |
| Author: | Bigrich [ Wed May 13, 2015 6:41 am ] |
| Author: | Walkers Bay Synd [ Thu May 14, 2015 12:59 am ] |
| Author: | mikecatt13 [ Thu May 14, 2015 9:15 am ] |
I went 8.5" Noveske on my .300BLK build. Did quite a bit of research and anything over 8" you still get good velocity, etc. (what the cartridge was designed for). I will try to find the velocity table I used to make my decision and post it here for you. I use a Barnes VOR-TX ammo with the 110 GR TAC-TX bullet. Fiance shot a 200 lb boar with it in texas last year and it performed great |
| Author: | Obezamatt [ Wed Jun 10, 2015 12:25 am ] |
300BLK will only run on Carbine length or shorter gas system, so that means carbine or pistol length gas only. It will not cycle reliably in a midlength according to Rsilvers. (correct me if I'm wrong). If you are getting a standard 16" barrel, then go with a Carbine length gas. If shorter than 16" (under 10", Pistol AR) then pistol length gas tube/block. ______________________________________ |
| Author: | Crews [ Sat Jun 13, 2015 6:55 pm ] |
The correct barrel length you're looking for is 9". You gain very little extra velocity past that. |
| Author: | Woodiebuster [ Sat Jun 20, 2015 6:03 pm ] |
Anything after 9" is a waste of steel And it was designed for a pistol length gas system |
| Author: | Russ [ Sat Jun 20, 2015 6:05 pm ] |
Nah, not a waste. That gun is very capable of great accuracy at 600 yards, but not out of the 9" with pistol length gas system. The 16" with carbine length does very well at that range. |
| Author: | Crews [ Wed Jul 01, 2015 8:41 pm ] |
| Author: | Russ [ Wed Jul 01, 2015 8:45 pm ] |
And you, sir, are correct. I was only addressing that specific post for info, because by the time we got to that point, I was in convo mode and completely ignoring the original purpose of the thread lol Sorry bout that, new zealander.. While im being a ninja, you coming this year to kill some woodies? |
| Author: | Walkers Bay Synd [ Mon Jul 20, 2015 3:10 am ] |
| Author: | Walkers Bay Synd [ Wed Oct 07, 2015 12:35 am ] |
Finally got it built. .. That was a long draw out project. Basic run down is its a 16 inch barrel with a 15inch keymod rail and waitaki engineering suppressor. Shoots nice with 110g v max home loads. Subs are the next load up. Got to go and thump some reds with it now. Did the maths on it other day and I'm sure I can go as short as a 10inch barrel and still be a rifle not full into the pistol category. |
| Author: | Crews [ Tue Oct 13, 2015 6:30 pm ] |
Love my 9.5" suppressed. |
| Author: | Bigrich [ Fri Oct 23, 2015 8:48 pm ] |
Enjoy my 8" blackout upper suppressed for sure. Put a 13" rail on it. Can't find a picture of it on my phone but will get one this weekend Sent from my iPhone using Tapatalk |
| Author: | calphil [ Sat Oct 24, 2015 3:37 am ] |
Got a 8.5" - waiting on stamp for suppressor Sent from my iPhone using Tapatalk |
| Author: | Walkers Bay Synd [ Sat Oct 24, 2015 4:04 am ] |
