It is currently Thu Apr 18, 2024 8:06 am
[ 9 posts ] |
Badchad17
Frog box
I️m looking into building a new frog box just seeing what everyone else uses
Wed May 02, 2018 4:47 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
Re: Frog box
Only guy I know that goes frogging just pulls rubber roof material over a bucket and holds it tight with a hose clamp. Then cuts a slit for the frogs.
I’m sure you down south are more sophisticated.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Wed May 02, 2018 5:42 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
Re: Frog box
La Boat Worx can build you a nice one
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Thu May 03, 2018 7:33 pm |
rangerp
Re: Frog box
what exactly is a "frog box"?
_________________ Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Thu May 03, 2018 8:48 pm |
Wchauvin
Re: Frog box
Use a live basket with a spring loaded lid. Get em at academy for 25 bucks and can fit about 80 frogs in our. Easy to drop them in and impossible for them to hop out.
Sun May 06, 2018 7:47 pm |
stu
Joined: Wed Mar 16, 2011 2:35 pm Posts: 608 Location: Deerfield Beach FL,
Re: Frog box
An old cooler works just fine.
_________________ Swomp 35 on an 1848 Alumitec Custom
Mon May 07, 2018 9:07 am |
daddyflea
Re: Frog box
i always killed mine before I put them in a Bucket, but them suckers do have a habit of reviving.
Wed May 16, 2018 7:43 am |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
Re: Frog box
[quote="stu"]An old cooler works just fine.
I use an old ice chest and cut a small rectangle in the top with a jigsaw.
From the inside of the top, I closed that hole with a piece of plywood and a door spring/hinge bolted to the plywood and the cooler.
When you push the frog in, the little door closes behind your hand. I will post pics later.
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
Fri Aug 24, 2018 1:44 pm |
dead animal
Re: Frog box
I get a short piece of 3 or 4'' pvc and tape a decoy sack to it, then hang it on the side of the boat. throw frogs in till u get worried about them jumping out, then throw the sack in a icechest and tape on another one.
I got tired of scratching my hands up on my wire frog cages.
Sat Aug 25, 2018 1:30 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 127 guests |
