| Frog box http://mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=72403 |
| Author: | Badchad17 [ Wed May 02, 2018 4:47 pm ] |
| Post subject: | Frog box |
I️m looking into building a new frog box just seeing what everyone else uses Sent from my iPhone using Tapatalk |
| Author: | 4Cody4 [ Wed May 02, 2018 5:42 pm ] |
| Post subject: | Re: Frog box |
Only guy I know that goes frogging just pulls rubber roof material over a bucket and holds it tight with a hose clamp. Then cuts a slit for the frogs. I’m sure you down south are more sophisticated. Sent from my iPhone using Tapatalk |
| Author: | WhoDat88 [ Thu May 03, 2018 7:33 pm ] |
La Boat Worx can build you a nice one |
| Author: | rangerp [ Thu May 03, 2018 8:48 pm ] |
what exactly is a "frog box"? |
| Author: | Wchauvin [ Sun May 06, 2018 7:47 pm ] |
Use a live basket with a spring loaded lid. Get em at academy for 25 bucks and can fit about 80 frogs in our. Easy to drop them in and impossible for them to hop out. |
| Author: | stu [ Mon May 07, 2018 9:07 am ] |
An old cooler works just fine. Sent from my iPhone using Tapatalk |
| Author: | daddyflea [ Wed May 16, 2018 7:43 am ] |
i always killed mine before I put them in a Bucket, but them suckers do have a habit of reviving. |
| Author: | dpd [ Fri Aug 24, 2018 1:44 pm ] |
[quote="stu"]An old cooler works just fine. I use an old ice chest and cut a small rectangle in the top with a jigsaw. From the inside of the top, I closed that hole with a piece of plywood and a door spring/hinge bolted to the plywood and the cooler. When you push the frog in, the little door closes behind your hand. I will post pics later. |
| Author: | dead animal [ Sat Aug 25, 2018 1:30 pm ] |
I get a short piece of 3 or 4'' pvc and tape a decoy sack to it, then hang it on the side of the boat. throw frogs in till u get worried about them jumping out, then throw the sack in a icechest and tape on another one. I got tired of scratching my hands up on my wire frog cages. |
