It is currently Thu Aug 20, 2026 1:18 pm
[ 9 posts ] |
Badchad17
 Frog box
I️m looking into building a new frog box just seeing what everyone else uses
| Wed May 02, 2018 4:47 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
 Re: Frog box
Only guy I know that goes frogging just pulls rubber roof material over a bucket and holds it tight with a hose clamp. Then cuts a slit for the frogs.
I’m sure you down south are more sophisticated.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Wed May 02, 2018 5:42 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
 Re: Frog box
La Boat Worx can build you a nice one
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
| Thu May 03, 2018 7:33 pm |
rangerp
 Re: Frog box
what exactly is a "frog box"?
_________________ Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
| Thu May 03, 2018 8:48 pm |
Wchauvin
 Re: Frog box
Use a live basket with a spring loaded lid. Get em at academy for 25 bucks and can fit about 80 frogs in our. Easy to drop them in and impossible for them to hop out.
| Sun May 06, 2018 7:47 pm |
stu
Joined: Wed Mar 16, 2011 2:35 pm Posts: 608 Location: Deerfield Beach FL,
 Re: Frog box
An old cooler works just fine.
_________________ Swomp 35 on an 1848 Alumitec Custom
| Mon May 07, 2018 9:07 am |
daddyflea
 Re: Frog box
i always killed mine before I put them in a Bucket, but them suckers do have a habit of reviving.
| Wed May 16, 2018 7:43 am |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
 Re: Frog box
[quote="stu"]An old cooler works just fine.
I use an old ice chest and cut a small rectangle in the top with a jigsaw.
From the inside of the top, I closed that hole with a piece of plywood and a door spring/hinge bolted to the plywood and the cooler.
When you push the frog in, the little door closes behind your hand. I will post pics later.
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
| Fri Aug 24, 2018 1:44 pm |
dead animal
 Re: Frog box
I get a short piece of 3 or 4'' pvc and tape a decoy sack to it, then hang it on the side of the boat. throw frogs in till u get worried about them jumping out, then throw the sack in a icechest and tape on another one.
I got tired of scratching my hands up on my wire frog cages.
| Sat Aug 25, 2018 1:30 pm |
[ 9 posts ] |
