| Small blocks http://mudmotortalk.com/mmt_v2/viewtopic.php?f=83&t=49577 |
| Author: | calphil [ Fri Jan 24, 2014 10:05 pm ] |
| Post subject: | Small blocks |
Who is coming that gonna be in the small block crew 27/25?? Just seeing who i will be able to hang with .. |
| Author: | TPerkins [ Sat Jan 25, 2014 12:46 pm ] |
I'll be there , just need the weather to cooperate so I can finish my GG. |
| Author: | txkingfisher [ Sat Jan 25, 2014 12:50 pm ] |
| Post subject: | Re: Small blocks |
14hp for the win bitches!!!! |
| Author: | calphil [ Sat Jan 25, 2014 2:07 pm ] |
This week should be good to finish up ... Cool weather and no humidity .. I may try having my cousin do mine this week also |
| Author: | marsh mule [ Sat Feb 01, 2014 11:24 am ] |
Me |
| Author: | bbarras85 [ Tue Feb 04, 2014 9:58 pm ] |
I'm too lazy to go through the whole gator glide process. I'm gonna bring like six cans of Pam with me and spray it on the bottom of my boat at the hotel. |
| Author: | Bigrich [ Tue Feb 04, 2014 9:59 pm ] |
| Author: | bbarras85 [ Tue Feb 04, 2014 10:41 pm ] |
Hahaha |
| Author: | TPerkins [ Wed Feb 05, 2014 1:11 am ] |
G2 goes on in the AM. |
Double post. |
| Author: | Swampnuts [ Wed Feb 05, 2014 6:40 am ] |
I'll be there |
| Author: | coupe1975 [ Wed Feb 05, 2014 6:57 am ] |
| Author: | coupe1975 [ Wed Feb 05, 2014 7:02 am ] |
Small block? Ill be there but my motors more like a wind up rubber band style |
| Author: | SETx Longtail [ Wed Feb 05, 2014 8:25 am ] |
I just wrap my pull rope around the prop and give it hell... If that won't do it I have the kick start for backup. |
| Author: | calphil [ Wed Feb 05, 2014 11:54 am ] |
Tad what color did you go with for the G2 |
| Author: | TPerkins [ Wed Feb 05, 2014 1:05 pm ] |
Marsh mud. |
| Author: | CLICKSTER [ Wed Feb 05, 2014 1:09 pm ] |
Ill be out there all day friday. I was just informed my daughter has a Select Vollyball Tourney that saturday so i wont make it. but i got a small block. |
| Author: | eljefe [ Wed Feb 05, 2014 1:18 pm ] |
Im gonna be there......i worked the intake some more. Its not where i want it yet but the sharp edge 90 degree angle has a much smoother transition now and all the flashing is ground and polished. After the mud run, im gonna pull the motor off and gg the bottom and while motor is off, i may pull the heads and see what can be done there. |
| Author: | TPerkins [ Wed Feb 05, 2014 5:56 pm ] |
final coat done. |
| Author: | txkingfisher [ Wed Feb 05, 2014 6:14 pm ] |
Man, I need some motivation to get off my butt and work on my motor again. I tore it down the day before yesterday and haven't touched it since. Been messing around with the throttle ever since I bought it and no matter what I do it is impossible to get full travel out of it. I ordered a new throttle lever on ebay but I'm not sure if it's going to have enough travel until it gets here and I hook it up. This thing has been really frustrating lately. It has always had a habit of dying for no good reason. Last time I took it out it would run great out of the water/mud but as soon as you put the prop down it died like someone turned the key off (no bogging or out of the ordinary sounds). It would happen anywhere from immediately to 15 seconds or so after a load was put on it. I drained the carb bowl afterward and everything that came out looked like pure clean gas. I wonder if the carb is screwed up because the primer bulb floods the engine so bad gas comes out of the muffler at the slightest squeeze. Shouldn't the float stop the flow of gas once the bowl is full??? |
| Author: | coupe1975 [ Wed Feb 05, 2014 7:54 pm ] |
Don't want to sound like a but hike at all but this is as simple as it gets when it comes to floats https://www.youtube.com/watch?v=DbNFJYb ... ata_player |
| Author: | txkingfisher [ Wed Feb 05, 2014 8:07 pm ] |
I don't exactly know what a but hike is, but I dont think you sound like one at all and I appreciate the link. So according to this video (and the most basic laws of physics) my carb is fukked right? I wouldn't necessarily expect the float to stop all the pressure from the bulb but I would expect at the very least a noticeable back pressure on the bulb...... Feel free to explain everything to me like I'm 5 years old. I know very little about small gasoline engines. |
| Author: | coupe1975 [ Wed Feb 05, 2014 8:41 pm ] |
Start another thread so this ones not hijacked. And I mentioned butt hole. Just git fat fingers, bad auto finish on my phone |
