It is currently Fri Feb 13, 2026 12:02 pm
[ 4 posts ] |
Oil/Grease below clutch???
Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
I am getting a bunch of oil or grease build up below the clutch. Is this something to be worried with or is it normal? I thougth maybe I put too much grease in the grease jerks but this is kind of a milky color. I do have a case gasket leak that hasn't been fixed, but I don't think it is related to this as I am not loosing that much oil.
Suggestions?
_________________ WC Custom 1854
| Sun Mar 08, 2009 6:22 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
 Re: Oil/Grease below clutch???
Water is getting in lower unit!Mine did the same thing,Change the seals!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Sun Mar 08, 2009 8:31 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
Gear lube from the lower unit. Grease will not change color and mix with water like that. Probably need a new upper seal.
_________________ 18x48 Charles Leonard / 36PD
| Sun Mar 08, 2009 8:45 pm |
Full Throttle
What's involved with changing the seals???? Is it an easy job? The engine only has 60 hours on it. How much will the seals run?
| Mon Mar 09, 2009 5:52 am |
[ 4 posts ] |
