It is currently Sat Jan 31, 2026 5:54 am
Reply to topic  [ 9 posts ]
 Ethanol gas issues with small engines ?
Post Ethanol gas issues with small engines ?
anyone had any engine issues caused by the added ethanol in fuels these days ? Small engine shops are covered up with the burnt-up engines.
My rig is built to go,not for show
Sat Mar 14, 2009 12:00 pm
Post Re: Ethanol gas issues with small engines ?
I hope I dont have any issues. Dat would suck yea! :twisted:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Sat Mar 14, 2009 3:12 pm
Ethanol should provide a cleaner (hotter) burn. If anything ethanol should reduce most of the issues with bad fuel and engine sludge. Only reason I see that ethanol alone would be the cause is the % in the fuel was too high and these small engines dont have the compression to contain the burn.
Sun Mar 15, 2009 7:16 am
one of the big things with ethanol that i've seen is when you let the gas (regular unleaded) sit for awhile or even sometimes just a week that the etahnol gums up the carb
Had to rebuild carb on my weldin machine 3 times due to etanol gumming up the jets and floats.
I run supreme fuel (93 octane here in TX) in all my carberated (sp?) engines b/c it doesnt have near the ethanol if any as regular does
I've noticed even in my 2007 toyota tacoma that it takes away from the performance and efficiency just with the 10% in regular gasoline
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sun Mar 15, 2009 10:22 am
Lord Please Help Me
Sun Mar 15, 2009 7:19 pm
my friend at autozone says ethanol is the devil.
Tue Mar 17, 2009 9:54 pm
one problem with ethonal is that you can get phase seperation. That is the ethonal/alcohol will seperate form the fuel. Lot of guys think this is water in the gas, but if you "pour" it off and lite it, it WILL make a large flame
just my 2 cents
1648 PD
32pd
Tue Mar 17, 2009 10:42 pm
Had to use ethanol in motors in my area . In the beginning we had trouble with it messing up fuel lines and rubber seals, now in 2009 no one complains anymore. Most motors that were harmed have been trashed in the junk yard by now.
Try using this stuff as it needs a stabilizer to keep it from getting "gummy" after a month or so..
Wed Mar 18, 2009 7:28 pm
Wed Mar 18, 2009 7:52 pm
