It is currently Sun Mar 29, 2026 4:06 pm
Reply to topic  [ 26 posts ]
 New 35cdi go-devil longtail
Post New 35cdi go-devil longtail
Well just ordered a new 35 cdi go-devil for my 1656gd boat cant wait for it to get here and try out. Plus coco sending me a rear floatation that they put in the back of the boat like the new gd boats have. He is a nice guy and the service has been great. also sent me new foam awhile back with all the stuff to put it back in the boat.
Prodigy 1851 elite timber , 4400 HDR .
Wed Nov 10, 2010 5:49 pm
Post Re: New 35cdi go-devil longtail
awsome man!! post up some pics of that bad boy when u get it!
Gatortail 1846 35hp GTR with calens stage 2 mods
Wed Nov 10, 2010 5:55 pm
No problem. Will do and ill get some reviews when i get a chance.
Wed Nov 10, 2010 6:34 pm
I went and picked it up for him in jackson today. We got it put together and on the boat. Went for a liltest run and seems to be pretty stout. Gonna try to take mine and his out tomm evening and run em a bit
Fri Nov 12, 2010 7:01 pm
Thats right, remind me to bring the gps.
Fri Nov 12, 2010 7:07 pm
That rear flotation is a pain. At least it is for me. Takes up too much space and won't let you put the handle all the way down to the floor.
17*38 Klibert 23GDLT
Fri Nov 12, 2010 7:53 pm
Iam gona look at it good before i put it in, just to make sure if i like it or not.
Fri Nov 12, 2010 9:17 pm
Took it out 2day just for a min. Noticed the rpm stayed about 3400. Does that sound about right ?
Fri Nov 12, 2010 9:28 pm
what speed did u get at that rpm?
Fri Nov 12, 2010 9:29 pm
Didnt have my gps , but i will tomorrow. Did notice that it went go down to 3360 with with 3 people and 3400 with just me.
Fri Nov 12, 2010 9:34 pm
u should def be getiing at least close to 4000 rpm if u have the correct pitch prop and ur not trying to push a barge
Fri Nov 12, 2010 9:35 pm
10X6 Factory prop pushing a 1656gd and the motor aint even got a hour own it.
Fri Nov 12, 2010 9:41 pm
what does it turn out of water?
that doesnt sound right, i would check that the throttle is reaching the stop at WOT, and maybe adjust the governor. check it on the trailer, if the max rpm's are waay higher than with a load, the gov may need adjustment
Fri Nov 12, 2010 9:43 pm
Forgot 2 look just got here this evening so i put it 2 gather and went 2 water. ill have more info when i get out tomorrow. its reaching wot and its in the 1 slot own the gov.
Fri Nov 12, 2010 9:45 pm
well least the spring own the thing is in the 1 slot . lol Time 2 get a nother beer.
Fri Nov 12, 2010 9:50 pm
makin sure we on da same page-NO.1 slot_u mean at the end of the arm right?
Fri Nov 12, 2010 9:54 pm
Yea but the thing got numbers to. Noticed the spring didnt realy pull own it much at wot . Wonder if go-devil got these things turned down a bit?
Fri Nov 12, 2010 9:58 pm
u can get replacement springs that pull harder, theyre color coded. get a service manual for your engine from a lawnmower shop, it will tell you everything about adjusting rpm's. we all know more rpm's = more speed
Fri Nov 12, 2010 10:04 pm
yea, gona look that up thanks for the info figured that 3400 didnt sound right .
Fri Nov 12, 2010 10:07 pm
on da trailer, i get max 4350, sometimes 4400. wit jus me, 4100 and 22 or 23 mph. 25 gdlt
Fri Nov 12, 2010 10:09 pm
will check and report back tomorrow rpm, speeds.
Fri Nov 12, 2010 10:15 pm
Ok, out of water she is 3800. In water 3360/ 3400. Aint got any speeds own gps so ill get that first chance i get.
Sat Nov 13, 2010 2:51 pm
You can turn the gov up to 4300. The cdi has a built in rev limiter that won't let you over that anyway. Make sure the butterfly on the carb is opening all the way too.
Sat Nov 13, 2010 5:41 pm
it act like it is hiting the gov. how do i turn it up? Do i move the spring down the bar or what do i do?
Sat Nov 13, 2010 6:23 pm
you will know when rev is hitting. my 35 cdi lt starts popping drops me back to 4000 something scared the heck out of me the first time it happened. youl love it once ya get it set up right . mine drives it self dam near. Way better than my 18hp .
16X48 G3 MBLT BD4500
Sat Nov 13, 2010 8:51 pm
cron
