It is currently Thu Jul 03, 2025 11:00 am
Reply to topic  [ 10 posts ]
 35 hp GTR crank case failure
Post 35 hp GTR crank case failure
I have a stage 1 35 hp GTR on a heavy ass boat. At 9 hours it cracked the crank case and sheared off the dowl pin on the oil filter side. The crank case was replaced. At 11 hours the bolts became loose again, so i pulled them out cleaned them off and applied red lock tight and retorqued. At 14 hours the four bolts on the oil filter side sheared off in the block. Also the stock exhaust was cracked to hell and back in about 9 hours. It seems like something must be out of whack causing some kind of vibration that is shacking everything apart, but i don't feel that much vibration while driving. I would like to hear other peoples opinions on what it could be or if this is just what it is like to be a mud motor owner. At this point i really wish i would have kept my outboard at least i new it would get me back to the landing.
Mon Jan 03, 2011 7:29 pm
Post Re: 35 hp GTR crank case failure
That's not part of being a MM owner. If it were a stage 3, it wouldn't be that uncommon, but a stage 1 shoudln't be doing that. More knowlegable folks will chime in.
Put yer face in the myrtles.
Mon Jan 03, 2011 7:32 pm
Any other ideas. Also forgot to mention that the bolts on the opposite side of the oil filter have held fine.
Tue Jan 04, 2011 8:16 am
Ony my stage 3 I had similar problems. I drilled and tapped them larger and use arp bolts. Held better but still came loose. I have put heli coils in and are holding fine now. Try that
20x60 homemade with twin Prodrives
JH Chopper (YLM)if I have time will make a SH
Tue Jan 04, 2011 9:57 am
IMsO ~ You are havin' way too much troubles. I gots 'bout 500 hrs on mines ... and knock on wood ..... I have not had those problems yet ..... muffler .. yes ... but not all that crankcase trouble. I live purdy close to you so it would be easy fo me to come look at it ... but thats 'bout all I could do .... I ain't much of a mechanic.
Who put the new crankcase on it fo you ??
Tue Jan 04, 2011 10:13 am
Have you had the prop checked to make sure it's not out of balance? It's amazing how much damage that can cause.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jan 04, 2011 10:54 am
Yes i have already tried another prop. I had the other prop on when it sheared to bolts off at 14 hours.
Tue Jan 04, 2011 10:57 am
Who did your stage 1 mods?
Tue Jan 04, 2011 11:06 am
^ agreed.
If it's bein fixed by a warranty, somebody's gonna start lookin deeper into it, if not, they're just gonna let ya keep dumpin ya $$$ into their pockets.
what about the prop shaft? could be slightly bent. Something is causing excessive vibration for the bolts to back out / shear off. One in a million, but what about the cam? Could be slightly out of balance.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jan 04, 2011 11:09 am
Yes it has been done as warranty work.
Tue Jan 04, 2011 11:23 am
Users browsing this forum: No registered users and 119 guests
