It is currently Thu Apr 02, 2026 6:55 am
Reply to topic  [ 11 posts ]
 Motor trouble. Got a question
Post Motor trouble. Got a question
So I got a 25hp kohler go-devil and I went to start it the other day and all it would do is spin real fast(the motor). Usually when I go to crank it the prop turns too but it wasnt, but the shaft coming out of the motor wouldnt turn either. The wire screen on the front of the motor would turn like it usually does, but it turned wayyy faster than normal. I was wondering if anyone has ever had this problem. I know its probably something internal in the motor with the gears maybe, but I figured some of you guys could help me out. Thanks
1542 War Eagle with 25hp GDLT
Wed Jan 19, 2011 9:54 pm
Post Re: Motor trouble. Got a question
not a guru on this stuff for sure but sounds like you have a broke crankshaft. Dont understand how it would still spin half the shaft tho.
18x54 WC custom
36PD EFI
Wed Jan 19, 2011 9:58 pm
Wed Jan 19, 2011 10:05 pm
I would have to look at it to be sure tho. Second thought maybe the wire screen and flywheel came un pinned from the crank and the starter is spinning just the flywheel???? I am not sure how the flywheel is attached.
18x54 WC custom
36PD EFI
Wed Jan 19, 2011 10:21 pm
Something's definitely fukkd up, it does sound like the flywheel came loose somehow. The guru's will chime in I'm sure, good luck.
Can you turn the prop and get the motor to turn?
Put yer face in the myrtles.
Wed Jan 19, 2011 10:35 pm
Sounds like the flywheel came loose and broke the key. (The best! Easy fix)
OR
Something MAJOR broke inside (The worst! Get out the check book!) :o
"They call us civilized, cause we're easy to sneak up on!"
Thu Jan 20, 2011 7:38 am
you definitely have a stripped flywheel key. not a hard fix
Thu Jan 20, 2011 9:43 am
I believe autogateman and mike w are correct. The Woodruff key between the flywheel and crank on the 25 and 27 Kohlers are a weak spot. It usually shears as a result of hitting stumps or rocks repeatedly. I've seen it 3 or 4 times up here in Alaska. It happened to one of my friends while out moose hunting. He pried the flywheel off the crank, replaced the sheared key with a big cotter key he found in his tool box and finished the season. He said the engine never ran better. I saw an EFI 26 hp straight from the factory with a sheared key. Let us know what the fix is. Good luck.
Thu Jan 20, 2011 10:06 am
Thanks for the input guys. I had a friend of mine who works on small engines check it out this a.m. and he said it was the flywheel key. He put a new one in and said it runs like a champ. Now time to finish gettin after them ducks for me. Only got 2 weekends left :(
Thu Jan 20, 2011 11:26 am
glad you got it fixed bud, i had a gdlt 25 and it did the same exact thing
Thu Jan 20, 2011 11:28 am
..same here, 25 kholer with a new key, couldnt be happier.
Fri Jan 21, 2011 6:21 am
