muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
 decking heads
how much to deck the heads? I hear everything from 0.020-0.050
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
| Tue Feb 01, 2011 5:17 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: decking heads
Leave them alone, do carb and exhaust
| Tue Feb 01, 2011 5:19 pm |
muddiejeep
 Re: decking heads
| Tue Feb 01, 2011 5:20 pm |
take'emgator
 Re: decking heads
oh ok
| Tue Feb 01, 2011 5:26 pm |
cb5331
 Re: decking heads
| Tue Feb 01, 2011 5:27 pm |
muddiejeep
 Re: decking heads
going with SS valves with valve job, and springs are already shimmed.
| Tue Feb 01, 2011 5:37 pm |
50fps
 Re: decking heads
Does anybody have a source for stock size stainless valves?
| Tue Feb 01, 2011 5:49 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
 Re: decking heads
X2.....
_________________ If I can't Break it, it can't be Broke.............................
| Tue Feb 01, 2011 5:52 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: decking heads
What is shimmig and why does one do it? I'm thinking the decked heads shorten the distance between the stem and the rocker so one has to make up that distance by placing a washer to bring the spring and thus the rocker closer to the stem to return the spacing back to factory spec. I still not sure where the shim is inserted, however. Am I close?
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Tue Feb 01, 2011 5:54 pm |
cb5331
 Re: decking heads
| Tue Feb 01, 2011 6:04 pm |
cb5331
 Re: decking heads
| Tue Feb 01, 2011 6:05 pm |
dguidry
 Re: decking heads
So one can shim a valve or a valve spring, but its the later of which one does after decking heads. Correct?
| Tue Feb 01, 2011 6:34 pm |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
 Re: decking heads
_________________ 18x54 WC custom 36PD EFI
| Tue Feb 01, 2011 6:40 pm |
dguidry
 Re: decking heads
| Tue Feb 01, 2011 6:43 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: decking heads
u shim ur springs to give u more spring tension so u can turn more rpm's before u float ur valves u can do it with or without shaving ur heads!!!!!!
| Tue Feb 01, 2011 6:44 pm |
deadbird8
 Re: decking heads
| Wed Feb 02, 2011 5:51 am |
cb5331
 Re: decking heads
| Wed Feb 02, 2011 8:30 am |
drake1
 Re: decking heads
Hard to keep those seats from warping. Best to actualy get older heads with run time on them then recur seats and lap in stainless valves. The valves we use are stock size.
| Wed Feb 02, 2011 5:03 pm |
