It is currently Tue Jul 01, 2025 12:39 pm
[ 8 posts ] |
GreginLuling
 Oil leak - 36 PD
It looks like I have an oil leak on the back side of my 36 PD (2007). I'm guessing it is the gasket. Anyone knows what this is going to cost to fix? Probably not a job for me.
Fri Jan 28, 2011 2:31 pm |
bpurvis
Joined: Fri Jul 30, 2010 9:30 am Posts: 627 Location: Baton Rouge, LA
 Re: Oil leak - 36 PD
Mine is doing the same thing. Its a cheap fix and you can order the part directly from PD. Ive heard its not hard to do but I havent got around to fixing mine yet. Be sure to let me know how that goes if you decide to do it yourself.
_________________ Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Fri Jan 28, 2011 2:44 pm |
curcio13085
Fixed mine twice  not that hard but easier with a friend. Just a gasket not rocket science
_________________ 20x60 homemade with twin Prodrives JH Chopper (YLM)if I have time will make a SH
Fri Jan 28, 2011 2:47 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
I used one of the metal/rubber gasket from EVT on the 36 prodrive that I owned a couple of years ago and it worked great and the guy still runs it with no problem
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Sat Jan 29, 2011 6:52 am |
GreginLuling
While looking at it today, I now believe the leak is just above the gasket where the throttle goes through the engine block. There is movement in that shaft and I can't figure out if I will be able to adjust it. I sent KP an email with pictures. Hopefully it's not a big deal
Sun Jan 30, 2011 3:38 pm |
deadbird8
Thats the governor shaft- there is a seal for that shaft and it would be an easy fix, just make sure you readjust your governor plate when you put it back on. Thats an easy fix vs. pulling the motor to replace the case gasket.
Wed Feb 02, 2011 6:34 am |
GreginLuling
I emailed KP and he told me the same thing. He said the seal could be replaced but it is really not that tight of a seal and if the engine is overfilled or leans back to far for an extended period then it may leak. Coincidently, I had a hydraulic leak on my trim. The motor was leaning all the way back for a few days. I fixed the hydraulic leak and guess what? It appears that the oil stopped. Man, I love this site and Prodrive.
Thu Feb 03, 2011 8:35 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
I just changed the case gasket on a PD and it is also leaking from that same spot. Its not bad enough to worry about though. The gasket change aint hard at all if youre a little mechanically inclined.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Thu Feb 03, 2011 8:39 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 183 guests |
