It is currently Sat Dec 13, 2025 4:28 pm
Reply to topic  [ 28 posts ]
 Tell me why your 2 cent worth
Post Tell me why your 2 cent worth
Ok I have a 1656 with 20" sides I'm running a mb sport lite 35hp
Just me at 220 lb I'm getting 25-26 mph with two of us one at 200 and 220 getting 24-25 with 4 people one At 340,220,200,210 got 21 mph these are all in deep water is that good or not the motor has a 32" shaft and bps exhaust that's it
I hear everybody I get 30 mph out of my rig tell me how and why for a factory motor
1860 center console 36 PD
Duck Down Express
[color=#FFBF00]Team Pro-Drive
Sun Feb 06, 2011 7:39 pm
Post Re: Tell me why
Most likley because people lie about how fast they go...
More times than not a stock rig dont go 30... do you have a mm hull, is it hooked, is your prop worn?
Sun Feb 06, 2011 7:50 pm
Its a 1656 slick bottom no hooks square chine and prop is 12" not 12.25 so it is worn a little
Duck Down Express
Sun Feb 06, 2011 7:55 pm
Some boat/motor combos just run better than others
Sun Feb 06, 2011 8:03 pm
Post Re: Tell me why your 2 cent worth
Where are all your batteries/ gas tank?
Is there any uneven weight?
Sun Feb 06, 2011 8:04 pm
Every thing is gas tank and one batt in front one batt in back the transom was built per mb 17 degree at 19" tall so are the speeds ok do you think a carb would help
Duck Down Express
Sun Feb 06, 2011 8:09 pm
Did you turn ya hat around backwards?
PM gigafowl, he can give you tips on foot placement to go 1 mph faster.
Sun Feb 06, 2011 8:12 pm
Hat was turned around
Duck Down Express
Sun Feb 06, 2011 8:15 pm
Maybe i missed it but...what type of boat do you have?
Sun Feb 06, 2011 8:18 pm
Custom built
Duck Down Express
Sun Feb 06, 2011 8:22 pm
May be a problem with your hull.. Your boat with only you should be running 29/30.
Does your boat feel as if it is runnning front heavy? (sucking)
Sun Feb 06, 2011 8:28 pm
No it's on plan it fills good so I don't know what it is
Duck Down Express
Sun Feb 06, 2011 8:32 pm
If you have a bible,
Pray about it..
That's what we do.
Sun Feb 06, 2011 8:43 pm
Yep thanks for help
Duck Down Express
Sun Feb 06, 2011 8:53 pm
Check your engine rpm's. You should be running in excess of 3950 rpm's when in the water, trimmed right with only you.
Also check the bottom of your hull, make sure it is flat and no hooks. These 2 things are the biggest factors if your prop is in good shape.
Put yer face in the myrtles.
Sun Feb 06, 2011 10:18 pm
ttt
Duck Down Express
Mon Feb 07, 2011 6:38 am
I think your loaded speeds with a stock motor at 21 mph is doin pretty good for that short boat.
Mon Feb 07, 2011 8:37 am
What would a carb do
Duck Down Express
Mon Feb 07, 2011 7:43 pm
Mon Feb 07, 2011 8:54 pm
Mon Feb 07, 2011 8:55 pm
Here we go foking up a thread im just try to find out some things on how every body on here that has a 35 hp or 36hp does 30 mph in there rigs
Duck Down Express
Tue Feb 08, 2011 6:24 am
1750GATOR TRAX &MB4000&MPE
Tue Feb 08, 2011 7:45 am
x2
Tue Feb 08, 2011 8:03 am
Tue Feb 08, 2011 8:13 am
Tue Feb 08, 2011 8:38 am
Tue Feb 08, 2011 8:47 am
All speeds I posted are in 15-20. Ft water
Duck Down Express
Tue Feb 08, 2011 9:49 am
