It is currently Sat Jul 26, 2025 7:29 am
Reply to topic  [ 66 posts ]  Go to page 1, 2  Next
 05 silverado......help!
Post 05 silverado......help!
i have an 05 silverado with 5.3, 5'' lift and 35's well since the day ive got it i found it to be a little sluggish. in reverse it wont peal out and takers off slow untill about 30mph then kinda seems to take off(when i stomp it). any suggestions?
Mon Apr 04, 2011 5:36 pm
Post Re: 05 silverado......help!
Gears to off set the 35s and get a tune
Mon Apr 04, 2011 5:41 pm
all my friends have the same thing and theres performe way better then mine
Mon Apr 04, 2011 5:42 pm
you dont have a check engine light?
They dont have a tune?
Same wheels? or at least weight wise
heaver wheels and tires will slow you down
Mon Apr 04, 2011 5:46 pm
i dont have a light on right now it will come on from time to time. we all have the same size wheels and tires and my dad has a little bigger tires and performs better. none of us have a tuner tried one on it one tima and made no acceleration difference on my truck. i also have k/n cold air intake and that made no difference. the truck has 140000 on it but should still have plenty left. was told could be my cats, mass airflow sensor, or injectors but dont know how to narrow it down.
Mon Apr 04, 2011 5:54 pm
go in your glove box and look at the codes on the sticker at the bottom..
look for gu6 or gt4 or gt5
My bet from what you are saying is that you have 3.42 gears which is gu6 code.
Edit: I have a 05 z71 with 3.42 gears and 33" swampers and it was a dog for pulling anything. Would shift in and out of OD a lot.
I gave up mud motors
Mon Apr 04, 2011 6:05 pm
yea ive done that and sure nuf it 3:42 same as everyone else
Mon Apr 04, 2011 6:08 pm
go get any codes read... If your check engine light came on it should have stored the codes in your PCM as long as you havnt disconnected your battery since then.
35s with 3.42 gears is a lot on these trucks. If you plan on keeping the truck if I were you I'd invest in some gears. about 2k at cajun offroad in lafayette. I'd suggest atleast 4.56. Your transmission will thank you also and last longer and run at cooler temps.
Also it wouldnt hurt to change your fuel filter and make sure that the k/n is clean and oiled properly.
Mon Apr 04, 2011 6:13 pm
bad thing is the truck doesnt have a fuel filter on the frame it in the tank and one piece witht the pump which cost 500
Mon Apr 04, 2011 6:53 pm
4.56 gears will solve your problem....also may take it and have the trans fluid and filter changed (not flushed). also if/when you plan to gear it, you might upgrade the locker. the stock ones' springs (with heavier wheels/tires) become week and brittle begin to slip under a load (in turns mostly).
1748 prodrive 36 fpr w/ some bolt ons...
Mon Apr 04, 2011 7:12 pm
i want to gear it but just want to see whats wrong before i do gear it. something must be wrong my friends respond way quicker then my truck i ran injector cleaner through it but didnt make a diff
Mon Apr 04, 2011 7:13 pm
Mon Apr 04, 2011 7:14 pm
whats the 8 digit in your vin?
Mon Apr 04, 2011 7:15 pm
its a 5 and thanks for the help
Mon Apr 04, 2011 7:17 pm
the 8th digit is a 5? also have you checked your trans fluid lately? sometimes (with the load thats on it all time) some fluid will burn off and cause the valves in the valve body to gum up not get the full range the need throughout the rpm range....
Mon Apr 04, 2011 7:21 pm
sorry its a T
Mon Apr 04, 2011 7:26 pm
and i have a new trans
[quote="T-Bubba"]look for gu6 or gt4 or gt5
what do the other two stand for?
Mon Apr 04, 2011 7:38 pm
whenever you think about it, check your buddies vin. in05, 06 and 07 classics they have an option of a vin code z which is a higher output 5.3 (flat tops) this may be the difference. most were on canadian built models with the block heater... they are a bit more torqy than the t codes. but all in all, its gonna boil down to gearing....
Mon Apr 04, 2011 7:39 pm
If it hasn't gotten worse, then this solution is probably unlikely, but I had an 04 Z71 Tahoe that started acting weird and very quickly afterwards didn't even have the power to get me all the way across the bridge over the river on the way home.
Turned out the ceramic in the cats had come loose and rotated 90 degrees, blocking my exhaust flow to the point it was fouling 2 cylinders and bogging the engine almost to the point of shutting down. Simple check was to disconnect the exhaust at the manifolds and see if it picks up rpm at a faster rate. If so, yank em.
Like I said, probably not your answer, but disconnecting at the manifolds will at least confirm its not between there and the tailpipe.
Good luck!
17x54 Gen 3 EFI
Mon Apr 04, 2011 7:41 pm
Mon Apr 04, 2011 7:42 pm
yea i was thinking it was the cats but is there a specific thing the engine will do if it the cats clogged?
Mon Apr 04, 2011 7:44 pm
Mon Apr 04, 2011 7:47 pm
easy way to tell if cats take a temp before the cat and after <off the pipe> and there should be a diff but if there is a lot then the cat is clogged up
driving a gd in ur lake
and i aprove this message
Mon Apr 04, 2011 7:50 pm
the L33...
is your engine block aluminum or cast iron?
the l33 does run and have more power than iron block 5.3
Mon Apr 04, 2011 7:51 pm
Click this link and enter your VIN number. It will tell you everything about your truck, all it's features, and how many there are exactly like it. Funny, there are only 3 of mine.
http://www.compnine.com/vid.php
Put yer face in the myrtles.
Mon Apr 04, 2011 7:54 pm
ita steel block
Mon Apr 04, 2011 7:57 pm
steel block is 290 horse and the aluminum is 315 if i recal correctly.... that might be the difference.
magnaflow high flow cats or no cats with a 3" dynomax bulllet would sound amazing and flow awsome.
if you get a tuner dont go with a handheld.. go with a custom tune.
Mon Apr 04, 2011 7:59 pm
anyone hear of thunder racing?
Mon Apr 04, 2011 8:06 pm
is that a speed shop?
Mon Apr 04, 2011 8:07 pm
a performance shop in gonzales and was wondering if anyone had any feedback for them
Mon Apr 04, 2011 8:08 pm
they do custom tuning and dyno
Mon Apr 04, 2011 8:09 pm
rod or matt might know about them
Mon Apr 04, 2011 8:16 pm
do they know what theyre doing and does anyone recommend anywhere else?
Mon Apr 04, 2011 8:18 pm
Dont go to Thunder --- Check out Futral in Walker -- they do a good job,
I know someone that has HP Tuners and knows how to tune well (had a 12 second z71 lol)
Mon Apr 04, 2011 8:21 pm
i need to get him to tune my tahoe asap
Mon Apr 04, 2011 8:23 pm
12 sec dats rolling. i had a single cab silverado that ran 13's and i thought i had something
Mon Apr 04, 2011 8:25 pm
Yeas and no, there descent but as far as tuning goes the guy that used to tune for them left and opened his own shop with a dyno. If I were to get a tune it would be from him, hes in industriplex off of siegan in Baton Rouge its called engine power systems. He's a nice guy and knows his shit also theres Futral motorsports in Denham Springs I haven't used him but hear nothing but good from there.
What are you wanting to do performance wise?
Mon Apr 04, 2011 8:29 pm
I would talk to Matt -white1- before any of the shops.
sent from my HTC inspire
Mon Apr 04, 2011 8:31 pm
Users browsing this forum: No registered users and 133 guests
