It is currently Tue Sep 23, 2025 10:11 am
Reply to topic  [ 5 posts ]
 What to use as sealant on lower unit
Post What to use as sealant on lower unit
I recently changed the seals on the lower end of the shaft on a 2008 mudbuddy long tail (27 hp). The stainless screw in cap at the end of the shaft that holds the seals in place has an o-ring at the base of the threads. Mud buddy uses some fancy aircraft grade sealant to help creat a watertight seal when it is closed back up. Any opinions out there on what to use that you can find at a local auto store. It would need something that would not harden like glue- maybe engine gasket sealant? Do you even need to seal it or just tighten it down and not worry about it? Thanks
Thu Mar 31, 2011 12:14 pm
Post Re: What to use as sealant on lower unit
I use a sealant called "The Right Stuff" from any auto parts store when I rebuild differentials. It is some good stuff. I'm sure it can be used just fine in that application.
Thu Mar 31, 2011 12:15 pm
Thanks for the info. I will look for some.
Thu Mar 31, 2011 12:25 pm
it is a gasket shellac. I think permatex is the one that has the "indian head" brand. I use one from loctite called aviation gasket sealant. it is very messy and has to wear off so be careful.
1554 excel- custom MB sport totin a stage II generac temporarily
20XRD Bullet- 300X Merc
Tue May 03, 2011 11:41 am
Super black
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Wed May 04, 2011 11:54 am
