It is currently Mon Jul 07, 2025 5:11 pm
Reply to topic  [ 7 posts ]
 gear reduction
Post gear reduction
Im looking into gettin a small LT 9hp -12hp range. I see that MB makes a couple gear reduction models. Im told that it enables u to run a larger prop,resulting in better performance out of a smaller MM. What do u guys think,, im trying to keep the weight down but i need to be able to push myself over a log or stump if i get high centered,,i dont care about speed at all. Im am outfittin a 14/36 weldbuilt crawdad .80. Seems to me you would loose in rpms at the prop but gain pitch with the larger prop,, would u just end up were u started.
off the streets and on the creeks
15/42 crawdad 23 swomp
Tue Jul 19, 2011 9:02 pm
Post Re: gear reduction
If it's the right balance of rpm loss and pitch gain, you may get a little bit better performance.
It should be harder to bog it down under a load too.
Tue Jul 19, 2011 9:06 pm
sounds logical,,,,
Wed Jul 20, 2011 9:40 pm
Orion Mud Motors also sells 1.5:1 gear reduction LT's you can get direct drive or centrifical clutch. Might be worth checking them out.
Russ
Thu Jul 21, 2011 8:58 pm
cool ,, never heard of them but ill giver er a look
Fri Jul 22, 2011 7:11 pm
Eat - Sleep - Hunt ! ! !
Fri Jul 22, 2011 7:52 pm
Good info
Sun Jul 24, 2011 9:18 pm
Users browsing this forum: No registered users and 113 guests
