darrel from meraux
Joined: Wed Feb 18, 2009 9:31 pm Posts: 584 Location: Meraux, LA
 gaskets
can anyone tell me a good website where theyr buying valve cover gaskets and oil filters for 29,31,and 35 vanguards.
_________________ 17x54 custom CC with stage 3 GTR.
| Fri May 22, 2009 8:26 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: gaskets
Darrel I just use the filters from walmart,as far as the valve cover gaskets never had to get any. What the hell you doing to that thing?
| Fri May 22, 2009 10:38 pm |
Dizzimator65
 Re: gaskets
Go to any Briggs Stratton dealer, (lawnmower etc.). They have the original filters and the valve cover gakets.
_________________ IF IT FLY, IT DIES !!!!!!!!!!
| Sat May 23, 2009 4:15 am |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: gaskets
Good luck finding anyone that stocks parts for the big block Briggs. Most will have to order the parts themselves so you might as well have parts sent to your house. I used these folks for a few things I have needed so far. I use the stock filters so Lowes, Home Depot or Walmart will have the them along with plugs. http://www.outdoordistributors.com/Brig ... smain.html
_________________ 18x48 Charles Leonard / 36PD
| Sat May 23, 2009 7:06 am |
darrel from meraux
 Re: gaskets
| Sat May 23, 2009 8:09 am |
dog walker
 Re: gaskets
Ya goin deep now
| Sat May 23, 2009 8:39 am |
darrel from meraux
 Re: gaskets
i know ill regret tinkering with it because once you start it never stops. hopefully ill be up again in a week or so then we can go make a run
| Sat May 23, 2009 8:59 am |
deadbird8
 Re: gaskets
That carb kit won't do you much good if your compression is that lopsided. Get your heads fixed.
| Sat May 23, 2009 10:06 am |
darrel from meraux
 Re: gaskets
no, those numbers are for 2 motors, one motor (sd) has 90 psi in both cylinders. and the lt has 140 in each cylinder. i did the carb 1st to try to gain a couple top speed mph since im only getting about 26 tops at 3600-3650 or so rpm.
| Sat May 23, 2009 12:00 pm |
stanco
 Re: gaskets
| Sat May 23, 2009 12:01 pm |
deadbird8
 Re: gaskets
| Sun May 24, 2009 3:43 am |
darrel from meraux
 Re: gaskets
sure is, wot out water i get 4100 but in water w/ 1 person i average 3500, i was lucky to get it to 3600-3650 a few times but when i do trim it up that much i start losing speed
| Sun May 24, 2009 7:40 am |
